porsche brakes
  • horvathg
    • Dec 2003
    • 556
    porsche brakes
    Hi guys,
    Help me please. I am in the bidding process for these things. What if I got them? What disc? What pads would I need? Or should I buy some decent grooved or drilled discs? But where? I am fed up with my present deceleration abilities.
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
  • horvathg
    • Dec 2003
    • 556
    Originally posted by horvathg
    Hi guys,
    Sorry. These.
    Gabor
    • S2 Ant
      • 3682
      I would assume that you would need the RS2 carriers and A8 discs, altho confirm that for certain with someone who has done the same mods
      Ant
      2011 Kawasaki Z1000
      • horvathg
        • Dec 2003
        • 556
        Ant,
        what are carriers? The adapters you mean? Those would be included. Or the pads? Sorry for my dullness.
        Gabor
        • S2 Ant
          • 3682
          The carriers are the mounting brackets for the Calliper, you will need these so that the calliper is mounted in the correct position.
          VAGParts sell them for much cheapness
          Ant
          2011 Kawasaki Z1000
          • horvathg
            • Dec 2003
            • 556
            These gizmos are included.
            Gabor
            • DTM S2
              • May 2004
              • 22
              Are those RS2 calipers? You need 323 x 30 disca as well as the mounting adapators/brackets which you are being sold together.
              I asw them on ebay also but I think the asking price is exorbitant.
              • horvathg
                • Dec 2003
                • 556
                Hi DTM,
                at the moment I am at 160 euros but it will surely rise till the end. I donno....
                Gabor
                • Stick Insect
                  • Dec 2003
                  • 2338
                  Hi guys,
                  Horvath, From the first photo it looks as though the calipers are rear Porsce units. The disk is not cross drilled. The standard caliper on the RS2 runs on 304 x 32mm disks.
                  If you use the RS2 caliper bracket with modern ( and better) porsche monoblocks then the disk size that is correct is 314MM x 28 but 30mm will fit in with a bit of filing of the pad posts.
                  If the calipers are Porsche 993 TT ( Big reds) then these are the same as the RS2 special option bigger brakes. The disk size is then 323 x 32 mm.
                  I hope this is not too confusing.
                  My suggestion:
                  Buy Porsche 996 monoblocks or Boxter S rear calipers which are the same. Get RS2 caliper brackets and use Audi A8 314 x 30mm disks which are cheap. Get grooved if you wish. Standard pads from Porsche or aftermarket Textar ones.
                  Easy and not silly money.
                  The split calipers ( bolts holding them together) have problems. Do yourself a favour and use a more modern caliper.
                  David
                  • horvathg
                    • Dec 2003
                    • 556
                    My suggestion:
                    David
                    David,
                    you are a real lexicon. I'm gonna ask the seller guy what these are. He advertised them as front ones. Its easy when the buyer is an amateur like me. Your advice is acknowledged greatfully (gratefully hmmm one of these are correct I hope).
                    cheers
                    Gabor
                    Gabor
                    • Stick Insect
                      • Dec 2003
                      • 2338
                      It's a pleasure.
                      Right second time. Ypou could always check on this site. Not brilliant but a help. www.freesearch.co.uk/dictionary
                      David
                      David,
                      cheers
                      Gabor
                      • horvathg
                        • Dec 2003
                        • 556
                        It's a pleasure.
                        David
                        The above mentioned brakes are 360 euros at this moment. How much should one pay for this pleasure? Anybody wants to sell me a set of usable brakes that works with some audi disc?
                        Gabor
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          Horvath, a pair of the calipers are about £200 + VAT, the mounting brackets are about £100.
                          pads and bits and bobs should come to another £100, disks £60
                          So in theory if all goes well it could be about £500 for the conversion!
                          Once I have done mine, I will be able to tell you better. It's very soon now, I'm spending too long fixing the Mondeo at the moment though!
                          David
                          • horvathg
                            • Dec 2003
                            • 556
                            David
                            Ahh............................................... ......Only?
                            Gabor
                            • SteveH
                              • 4460
                              David
                              You will also need new brake lines, as the RS2 caliper has it's fluid feed further down the caliper body than the Girling units.
                              Either make up some custom braided hoses or buy the RS2 items.
                              91 Modded 3B
                              14 A6 Avant Black Edition
