I'm going to purchase a set of Wilwood Caliper's to be used on my 20V CQ. The calipers will be used in concert with Zimmermann rotors. Since I don't track the car but use it for everyday use and occasional trips up to Road America, it should be adeqaute, no? Any yea's or nay's?
Wilwood 4 piston Calipers....
To my knowledge, Wilwood only do 1 design which is fully dust sealed for road use (midlite ??).
Although a lack of seals is not really a problem IMHO, it may just mean you will need to do a pistons out refurb every other pad change for piece of mind.
Nice calipers though & well respected for track use.
Could you elaborate more on your reply?
So far, yours is the only negative I've gotten from alot of people. From what others have told me, the Wilwoods are way better than the standard G60 brakes I have now on my CQ. Is the quality suspect or is their a flaw that apparently no one has discovered or suspected?
Timucin is on 5 stud hubs, but that shouldn't make a difference. You did not mention the new disk size, I feel they are just standard diameter. I feel the diameter of the disks needs to be increased to improve the braking. if it isn't then the calipers will be working harder on the small disks, overheating etc. I don't know what chape big disk options are avvailable for the 4 stud ( which is why I am changing to 5 studs!)
HTH
David
Originally posted by Stick InsectTimucin is on 5 stud hubs, but that shouldn't make a difference. You did not mention the new disk size, I feel they are just standard diameter. I feel the diameter of the disks needs to be increased to improve the braking. if it isn't then the calipers will be working harder on the small disks, overheating etc. I don't know what chape big disk options are avvailable for the 4 stud ( which is why I am changing to 5 studs!)
HTH
David
Forgot to say I feel the Porsche 944 calipers should fit onto standard disks. I was going to look at this but left it and was seduced by big disks and monoblocks. They look good in the packet
Must fit them!
David
