Well my front setup with the huge 4 pot Brembos are nearley compleate (picking the brackets up next week). (360x34 disc
The next step is the rear, I have 'smaller' (comparable to 996 fronts!!
) brembo 4 pots to go on the back, looking at the S4 350x30mm 4.2 V8 front rotor to go on the rear of the coupe but i need to get a handbrake caliper, has any one any expirience with Compbrake of HiSpec calipers?
Brembo ones come in at 250+vat so this is not a realistic option (new ones any way), I may look for Astonmartin or Ferrari spot caliper form somwhere like Douglas valley but i fear the price will be an issue here!
Dont even think of posting Wilwood, iv seen the picture.
http://info.wilwood.com/CaliperList1.aspx?subname=Mech Spot
Any thoughts?
)The next step is the rear, I have 'smaller' (comparable to 996 fronts!!
) brembo 4 pots to go on the back, looking at the S4 350x30mm 4.2 V8 front rotor to go on the rear of the coupe but i need to get a handbrake caliper, has any one any expirience with Compbrake of HiSpec calipers?Brembo ones come in at 250+vat so this is not a realistic option (new ones any way), I may look for Astonmartin or Ferrari spot caliper form somwhere like Douglas valley but i fear the price will be an issue here!
Any thoughts?
With the A8 (edit: S4/RS4) calipers you should be able to run 300mm or something rear discs. Should be enough?
