Now that the car is back on the road I feel that the brakes is not much better than stock brakes after the upgrade. I know it is difficult to explain, but how much improvement can I expect going to the Porsche calippers? Reading on the forum I expect a rather BIG improvement but this is not the case. Not sure which caliper it is, but I think it is GT 2 calippers. They have 140 mm cc bolt holes to carrier and are 4 pot monoblocks. I am also using the pads that came off the Porsche the calipers came from.
Some facts:
-The pedal is quite hard, almost like there is little brake assistance from hydraulic system. I can lock the wheels during hard braking if I want to, but I really have to step hard on the pedal.How can I find out if I have brake assistance?
-Brake pads are used (good thickness) but comes from the porsche the calippers came off.
-I get the (!) brake symbol with alarm for a few seconds during startups when the car has rested overnight. It then disappears.
-Stainless brake lines
-Brake reservoir and PAS reservoir is full.
In addition the ABS light has been on since the brake upgrade indicating ABS is switched off. I recently adjusted the rear left ABS sensor closer to "ABS ring" as this was to far from the ring. The ABS light then switched itself off indicating ABS should now be working, apart from a couple of times where I have seen it during driving, but when I stop and start the engine it dissapears again. The problem I got then is that the ABS seems to activate itself during slow brake downs (I get no alarms or lights when this happens)and it only activates from about 25 km/h down to zero/stop during slow braking. I can feel and hear the quick pulsing in the pedal when this happens.
Do I have 2 completely different problems or could the lack of brake effect be related to the ABS problem?
Could the porsche brake pads be off some kind that works better when they are hot, ie track pads of some sort?
Could the ABS problem be that the sensor I resently adjusted are still not correct distance to "ABS ring"
It should also be mentioned that at all vacum lines has been modified to fit a different inlet manifold, but I do not think the S2 brakes are vacum assisted?
Lots of question here but hope someone can guide me in the right direction here.
Johan
Some facts:
Johan
