The part numbers are 996.351.429 and .430. I think that is from a porsche 996 GT2. Fronts....I hope
I think you guys are right here. The "problem" is most likely due to pads,bedding in,not to much used and not tested under hard conditions. However, lets say the PAS pump is delivering alittle less pressure than it should, will this give less brake assistance and can the pump do this without giving any alarms on the autocheck?
The ABS issue is as you guys mentioned probably due to a sensor to close or to far from the ring. I resently adjusted rear left so it is probably this one. Will adjust it and se if it helps.
Leaving for offshore work shortly so will attack these issues when I get back.
Thanks for all your inputs
Who sells these in norway or anywhere for that matter? Preferably an online store as I am offshore now and want to have them waiting for me when I get home.
