I was at the mechanic talking to him about my RS2 intermittently cutting out(http://www.s2forum.com/forum/showthread.php?t=39568 ), while I was there he was poking around pulling relays (including fuel pump) and some plugs etc.
Anyway, I left, drove down the road 500m, braked for some traffic lights and the brake warning light came on. I turned the car off, started it again drove off down the road and it happened again. Got to work (only 2kms away from the mechanic) and the brakes were working fine. I left work early to head back to the mechanic's, the light came on again, brakes still working fine.
The mechanic thought it could have been the power steering fluid, that was fine, as is the brake fluid, he said it must have been a sensor. I went to drive off, got down the end of the drive, applied the brakes, the light came on again and the brake pedal was rock hard and vibrating with my foot pressed against. The brakes felt dead, firm and barely work.
Whats going on? Is it the brake bomb?
Also, I turned the car off and restarted it a number of times, the brake light comes on 35 seconds after starting the car. I pulled the ABS fuse but it still felt the same.
I have had a search on the forum but cant pin point the problem
Good forward to hearing your advice
