The 6 spokes are made by Speedline too. Just wanted to check as I seem to remember that the 5 spokes have worse clearance issues than the 6.
This was my setup courtesy of BRY (machined Seat brackets, no spacers etc.), not able to give wheel to calliper clearance as I sold the 16s a while ago, the radial clearance is plenty big enough (as can be seen). From memory, the axial clearance was in the 5-10mm region.
Custom brackets should address the fact that the bolts that attach the carriers to the hubs had too much stick through due to machining the faces to fit, it's not much but enough, this meant that the bolts had to be ground down.
, it is totally impossible to fit the 996 calipers + 314 discs in the 3B original rims??
