Porsche Brakes a plenty!
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    I just got these off ebay for $450 shipped with pads
    and I got the RS2 brackets from Europrice for $185...they used to be $210 I believe.
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
    • panzerwagen
      • 900
      David! Thanks fo any help you can offer! Question?
      When you say Europarts, do you mean Europrice? If it's Europrice, boy have you got that one wrong!! There are hundreds of places here in the States called Europarts.
      • panzerwagen
        • 900
        NoNonsense! You lucky dog!!
        Joe are you using 17' rims on your ride? What are you planning to use for hats?
        I'm saddled with 16" BBS RN rims that cost me a right nut so no way can I go bigger. Think I can use a Porsche Monoblock Calipers with my 16"s if I can score some kind of mounting adapters?
        • Stick Insect
          • Dec 2003
          • 2338
          Joe Posted the correct name EuroPrice, they do the hubs as well I believe....
          BIRA posted a list of wheels which clear and some that don't
          HTH
          David
          • NoNonsense
            Forum Sponsor
            • Apr 2004
            • 673
            #20
            I'm going the route of using the European A8 rotors, so 314x30mm rotors. No need for a custom hat. I may upgrade to the billzcat set up at a later date, or get custom brackets to fit the Audi S4 rotor, because there are many companies that make a 2-piece floating rotor to fit under the S4's calipers. The only thing about the bilzcat system that is holding me back, it that it's too new and not proven yet...but Richard is a great guy. I may be wrong, but I think a 32mm wide rotor (993tt rotors with custom hats) are too wide for the 996 caliper. Yes, you can machine 2mm off each pin, but when the rotor gets hot and expands, i think it may push on the pads...unless one shaves the pads before installing them.
            Joe "NoNonsense"
            axis motorsport
            • NoNonsense
              Forum Sponsor
              • Apr 2004
              • 673
              #21
              HTH
              David
              yes, i purchased my hubs through Alex at Europrice and paid out the nose, but that's what i really wanted, so i ate it. it'll be worth it, though, in a week to have nice brand spankin' new hubs, rotors and calipers and wheel bearings!
              Joe "NoNonsense"
              axis motorsport
              • Mikes2
                • 1704
                For the bracket you could use the Seat Ibiza Cupra R part which gives the same spacing as the RS2 item.
                Much cheaper at 18 GBP.
                Mike
                http://www.s2-audi.co.uk
                • Stick Insect
                  • Dec 2003
                  • 2338
                  Thanks for the info Mike. Just a quick one everyone the RS2 bracket sometimes needs shims ( washers) to space the caliper 100% correctly.
                  David
                  • panzerwagen
                    • 900
                    The Seat Ibiza Cupra R Part instead of the RS2?...
                    HMMM, maybe I'll ask Martyn at VAG parts if that's viable.
                    • Mikes2
                      • 1704
                      Vagparts cannot supply it. 6KL 615 421 is the part number. I got it through a VW dealer.
                      Mike
                      • Alistair E
                        • 479
                        #26
                        928 S4 / 968 CS calipers & discs
                        Can anyone tell me what size discs these calipers were designed to run on, diameter and thickness?
                        Alistair
                        • s2driveruk
                          • 12696
                          either 304x30 or 322x32 i think
                          1992 3b S2 Coupe
                          • Dr H
                            • 1175
                            If you mean the calipers in the pic at the begining of this thread then if they are from a 996 Carerra they were for 28mm thick (altough you can get 30mm to fit with a bit of work) and 318mm in diameter.
                            Please someone correct me if I'm wrong 'cause I'm no expert on this......
                            • Stick Insect
                              • Dec 2003
                              • 2338
                              Alistair
                              I Have the disk and caliper from a Carrera 2WD the disk size is 304mm x 32mm. It's sitting in my shed getting in the way......
                              I think the 928 and the 968CS is the same. The 993TT has a 322 x 32mm disk I think ( Big red set-up.
                              HTH
                              David
                              • Dr H
                                • 1175
                                @ David
                                Hmmmmmmmm.............why did the porsche site I just visited say different. The Boxter S is the same as the 996 Carrera and this gave the same (318 x 28mm)
                                Is your disk from a 996 or 993?
