any one removed the ABS from there track cars
  • trackslag
    Account Disabled
    • Sep 2009
    • 171
    as above dont know if worth keeping or not????????????????
  • mrtat2k9
    • Jan 2009
    • 659
    my 90 doesnt have it on and iv drove 90s with it on and i didnt like it but thats just me
      you have to be careful as the brake balance is controlled in the ABS module itself on ABYs IIRC - if you remove it you'll need to fit a bias valve.
      • trackslag
        Account Disabled
        • Sep 2009
        • 171
        Thats not so bad on a track car may come in handy having a bias valve.
        • trackslag
          Account Disabled
          • Sep 2009
          • 171
          has any one on here done this ???????????????????????????????????????????
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            The ABY has a separate bias valve, the same as the others.
            But a track toy would have an adjustable bias anyway.
            Just get on and bin the ABS. It should be straight forward enough. Just a few pipes to reroute.
            SS
              If its a pure track car I'd bin it. You'd need to switch it off anyway, you don't want it driving you into the armco if you spin. You need the wheels to lock when you tell them to.
              • hibby
                • Apr 2007
                • 215
                You can't switch the ABS off on an ABY. I am sure I seen someone fitting the switch to an ABY though, if it is not a dedicated track car that may be worth looking at.
                1990 Cq20v GTi Engineering RE2400
                1992 16v 80 quattro
                2004 A3
                • speeding-g60
                  • Aug 2008
                  • 1186
                  i took the ABS off the drag car.... and also the booster/bomb as well. Master Cylinder only, with Wilwood Proportioning valve for the rears...
                  the OEM prop/bias valve is right below the MC, at least here in America. it is a separate deal, not internal with the ABS. the ABS only does the front brakes here in USA, also.
                  • Audi_CQ
                    • 940
                    • Country: Norway
                    Why do you want to remove it
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      In what situations do you want to lock the wheels?
                      In my experience it's when people lock up the wheels they meet the armco and not the other way around.
                        If you're on the grass and spinning you want to lock the wheels till it comes round, last thing you want is for it to steer off in some random direction, we saw an RS4? do that at CC last year. ABS is for emergency braking in traffic in the rain when you're thinking about something else IMHO.
                        • lind4hl
                          • Jul 2008
                          • 2465
                          +1!
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            But what if you're on the grass because you don't have ABS?
                            If you are on the grass spinning and hit the brakes you will continue to spin even with ABS. If you want to be 100% sure just press the clutch and use the handbrake.
                            You may think that ABS and ESP is for people that can't drive, but you're wrong IMHO
                              ESP is outright dangerous - I forgot to turn it off when driving my GF's RX8 on track and the ESP decided mid corner that it didn't like what was happening so started braking random wheels - result... I went straight on and missed a tyre wall by 5 feet while travelling at about 50mph
                              ESP takes control away from the driver which is truely scary when it happens.
