Hello.
After the small reds 314mm conversion i have been thinking about brakes...
1) According to the family album, in my compi i have the master cylinder with the sizes: 23,81x13x22,5 (Girling) (smaller than the s2/rs2 piece), but im not sure because i cant find the part number on it.
I have at home a master cylinder from an 1992 urs4.
the family album shows it should be 25,40x13x22,5 (same dimensions as the s2 aby MC)
the part number of the urs4 MC is something like 154 135 617
Now the obvious questions:
Will the urs4 MC fit my brake servo "drum" (i think it should)
will there be any gain in brake power?
2) I also have the hydraulic brake servo from the urs4. according to the PN should be the same as the s2 piece.
What else do i need to install it?
Would the tandem pump from an s2 fit on my engine?
Is the bomb a must?
Enough for now
Thanx!
Is the bomb a must?
Enough for now
Thanx!
