Which Brake Upgarde For UR?
  • martinjs
    • 3205
    Do you know 'crisarc' on classic audi forum? He bought spinks car and swapped all the parts, brakes and RR engine etc onto his black 200Q treser.
    • steverrquattro
      • Oct 2006
      • 788
      I don't, but I'm registered on that forum so I can give him a PM.
      The brakes that you used (996.351.425/6 monoblocs) , was this on the 100Q with the S4 discs?.
      Steve
      1990 RR 20V
      1982 SWB UR - RS2 Engine
      • Acidburn
        • 13459
        5 stud I take it martin
        • martinjs
          • 3205
          Yes
          • martinjs
            • 3205
            Yes, could have done the same on spinks current 90q project but due to sticking with the 4 studs will be using the focus st disks.
            • steverrquattro
              • Oct 2006
              • 788
              Any advice on rears?
              Steve
              1990 RR 20V
              • martinjs
                • 3205
                Ive never done a rear conversion as such. An uprated pad with grooved disks maybe. How much hp will you be running? Depends what you will be using the car for really. Any trackdays?
                If i ever get another S2 (coupe of course) i'd really like to use brembo handbrake calipers with 996 or similar monobloc on the rear and make a bracket to hold the 2.
                • martinjs
                  • 3205
                  I can highly recommend Ferodo DS2500 pads for the fronts btw. They are awesome.
                  • steverrquattro
                    • Oct 2006
                    • 788
                    Initial target is 400BHP and yes definately trackdays.
                    I take it that the 996's can also be fitted to the rears on a UR as well then?
                    PS I like the idea of that brembo handbrake as well.
                    Steve
                    1990 RR 20V
                    • martinjs
                      • 3205
                      Yes it could be done but the problem is the handbrake. Im not that clued up with UR rear brakes but there is a documented conversion on the forum for the rear of the S2 using A8/S8 rear parts i believe. I will have a search. Dont know if something similar could be used on a UR.
                      • DJones
                        • Jun 2005
                        • 2020
                        In theory the bigger the front brakes the smaller/less effective you want the rears as the bigger front brakes will make the car nose dive more removing weight from the rear. As a consequence the rear will lock more easily even with standard rear brakes.
                        If you go bigger than standard rears particularly with a nose heavy Ur you will need to start fitting bias valves reducing there efficiency which begs the question of why fit them at all...
                        • martinjs
                          • 3205
                          The 20v Ur has 269 x 20mm rear disks already which is a pretty decent size tbh, just use grooved disks with uprated pads IMO.
                          • martinjs
                            • 3205
                            Yes, cant say i've ever seen a rear brake conversion on a UR, didnt even realise that RR rear disks were a bigger size. Like i say i never had much experience with ur rear brakes.
                            • steverrquattro
                              • Oct 2006
                              • 788
                              That makes sense Mr Jones - thanks. Think I'll leave the WR rears as is for present. Suppose I could always update to RR calipers if I felt it necessary at a later date.
                              Having said that the car has been off the road for 5 years so they're probably seized on anyway. If this is the case it wil be a good time to replace/upgrade to RR rears.
                              I've more or less decided now on:
                              1. Front 996's (996.351.425/6 monoblocs).
                              2. Custom made carriers via Kev Bambridge.
                              3. Sport Quattro or S4 321mm front discs.
                              4. Goodridge metal braided hoses.
                              5. Ferodo DS2500 pads
                              Steve
                              1990 RR 20V
                              • john johnson
                                • Jun 2009
                                • 190
                                There are 996 and 986 on American eBay for about £210 plus shipping Steve, well there was yesterday!
                                3 Urs to keep , 95 Avant,
                                shedmeister
                                http://s159.photobucket.com/albums/t144/jsquatts/
