Which Brake Upgarde For UR?
Not from what i've seen/heard I don't think they will.
Either the one's that volcano has or some porsche monoblocs will be enough for your car, remember its a very light car you don't want to overbrake it with anything mental, I turned down some 8 pot callipers at a stupidly low price as that would have been waaaay over the top.
Last time I looked at brake upgrades for urq struts I did look into rears and iirc the RR callipers are listed as the same as a6/s6 quattro avant and the sport quattro so might be an easy upgrade there - 269mm RR disc so a good size going up from the stock urq 245mm size disc.
strangely tho etka lists a 295mm disc on the sport quattro.Comment
FWIW: I have 996tt's calipers with 993tt rotors that fit under 17" rims
But it might be a pain in the rear to source the parts. If someone has a complete setup with brackets, hats, rotors and calipers that came off a UR ...GO FOR IT!Last edited by S6Sputnik; 21 December 2010, 01:35.Shawn Olsen Austin TX ACNA#1616
//95 S6 RS2// 13 A6 3.0 // 12 S4 MT // 12 GTI aprComment
