What do you think about EBC Turbo Groove brake on a S2 Coupè ABY?
  • Audi-Porsche Avant RS2
    • Sep 2008
    • 1041
    • Country: Italy
    Hello friends, what do you think about EBC Turbo Groove GD 604 (front) and GD 605 (rear) and Yellowstuff brake pads DP4711R (front) and DP4370R (rear) under a S2 Coupè ABY?
    Is a good choice or not?
    Thanks a lot!
    Bye
    Alessio
    My life and my loves
    Audi S6 C4 ABT Avant
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
  • dest
    • 4287
    From my own experiences, I would say bad choice.
    Every time Ive had EBC discs on heavy cars they have warped
      • Sep 2008
      • 1041
      • Country: Italy
      And Zimmermann?
      Thanks a lot!
      Bye
      Audi S2 Coupe ABY
      Audi S2 Avant
      Audi Cabriolet 2.0E
      • Evilgoat76
        • Feb 2010
        • 278
        • Home: Canada Current: United Kingdom
        Exact setup I have on the back of the S2, not had a single problem and after driving robs stock S2 I can say they do make a difference.
        Yellow stuff isnt too great when cold though and hey seem to really suffer if you get them wet, more so than standard pads I had on there. Just stay out of fords
        • s2driveruk
          • 12696
          nothing wrong in the zimmerman discs from personal experience
          1992 3b S2 Coupe
          • GazzaG60
            • 4133
            turbogroove discs are good if they are the ones im thinkking of. they anre not cheap though. dont touch their standard ones they will either warp disc or pad.
            ebc pads are ok on a budget.
            • 20Vcqdriver
              • 829
              Had some standard turbogroove discs once and they warped. No issues with the Black Diamond grooved discs I now use. Used EBC pads too but if it's not for the track they'll never get warm enough to work properly. USe Red. Also had good results with the Black Diamond Predator and Ferodo performance pads too.
              1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
              • dest
                • 4287
                After having EBC I tried Black Diamond with Predator pads, they were definitly better than EBC, but did have huge fade after a hard run on B roads
                • s2driveruk
                  • 12696
                  personally if you are stuck with a stock setup and trying to get best performance out of it, i'd go with a standard disc and get the best pad you can - seem to remember you can get hold of Pagid blues/oranges/blacks for the S2.
                  1992 3b S2 Coupe
                    • Sep 2008
                    • 1041
                    • Country: Italy
                    I have EBC Yellowstuff already on front and on rear of my RS2 that have the original upgraded brake system from Audi, so big red on front and original drilled discs on rear, I have test this setup during two trackdays in Monza and I'm happy, so I hope that under the S2 Turbogroove on front and on rear, EBC Yellowstuff on front and on rear and Fischer Dekra pipelines like under RS2 is a good setup too for normally use and also some trackdays, but for trackdays I'm not really sure.
                    Thanks a lot to all!
                    Alessio
                    Audi S2 Coupe ABY
                    Audi S2 Avant
                    Audi Cabriolet 2.0E
                      • Sep 2008
                      • 1041
                      • Country: Italy
                      Have you ever test Omnicompetition or TAR-OX brake discs on a S2 Coupe? I watch also for these brake discs instead of EBC.
                      Thanks a lot!
                      Bye
                      Alessio
                      Audi S2 Coupe ABY
                      Audi S2 Avant
                      Audi Cabriolet 2.0E
                      • madpugger
                        • Sep 2007
                        • 1901
                        I use yellowstuff on the S2, they are great IMO
                        Only used TG disks on a Pug 205 which used to warp disks (standard ones) in a day, they never warped and were very very good, nice progressive bite.
                        Le Mans 2012
                        Nurburgring 700
                        1995 S2 Avant
                          TBH you'd be better off spending the money on a 996 setup with plain Zimmermans and some mid-price pads, avoid Textars for track use but they're fine on the road.
                          Stock brakes will never haul up a 1.6 ton car that well IME. Mine were lethal with Pagid TQ pads!
                          Zimmerman X drilled are crap, I've had them on various cars and they wear unevenly and eventually crack, you don't really need X drilled unless the pads you run specifically require them due to out-gassing.
                          Better to get Brembo plain discs, a good quality product at a good price.
                            • Sep 2008
                            • 1041
                            • Country: Italy
                            What do you think about it?
                            Thanks a lot!
                            Bye
                            Alessio
                            Audi S2 Coupe ABY
                            Audi S2 Avant
                            Audi Cabriolet 2.0E
