Recap Re:996 calipers.....
  • jubjub
    • Nov 2003
    • 1239
    I have been reading the thread regarding the 996 calipers, but just to confirm if i went for a pair of these,what else would i need.I gather i need different mounting brackets,are these available off the shelf or custom made? Can anyone offer advice/BTDT on disc size/supplier and custom hose/supplier.The calipers i am looking at are GT3/996 turbo...
  • Dr H
    • 1175
    Matinjs is your man for custom calipers brackets - ****** works of art and very reasonably priced too!
    Corey really knows his stuff on brakes, maybe have a chat with him.
    Martin's brackets are for the 323x30mm A8/S8 discs but I guess these will not fit the RS2. Maybe you can use discs of the 996 turbo seeing as you have Porsche hubs?
    Ex 1994 Avant - now driving a Lotus 340r
    • S2 Ant
      • 3682
      There was talk of using mountings from a SEAT i believe in one of the threads... at only £18 each too!!!
      Ant
      2011 Kawasaki Z1000
      • S2 Ant
        • 3682
        Originally posted by mikes2
        For the bracket you could use the Seat Ibiza Cupra R part which gives the same spacing as the RS2 item.
        Much cheaper at 18 GBP.
        Dunno if this is true or not, but if it is, then bargain!!!!
        Ant
        2011 Kawasaki Z1000
        • 90quattrocoupe
          • Nov 2003
          • 771
          I posted pictures and write up on this site for the 996 brakes on front of coupe. Has breakdown of parts, and step by step procedure for mounting to front hub carrier.
          These are the pieces needed for upgrading a coupe from brake system to use Porsche 996 brakes. This model caliper comes on two different cars, the Porsche 996 or the Boxster S. The 996 brakes are black and the Boxster S brakes are red. It seems that you can get these calipers in silver...
