Finally found a great brake catalog from ATE
This is a sticky topic.
    Originally posted by S2central.net
    @Pete - can you source the complete rear caliper seal / refurb kits as well ?
    I need a pair for trusty old cast iron 38mm rears... Plus a pair for cast 43mm rears (as per RR quattro)
    I also need a pair for alloy 38mm from 2001 allroad
    Local motor factors have not been helpful so far
    These guys sell the Budweg rebuild kits and prices are very good.
    UK specialist supplier of car brake discs, pads, calipers & HEL braided hoses. Quality OE brake parts from top brands like Mintex & Brembo.
    I've rebuilt a pair of rear calipers - never again. Biggest PITA ever I think.
    Plump the extra cash for some exchange ones IMHO.
      EDIT they now seem to offer ATE master cylinders too
        Cheers for the link... I already renewed the faulty ones on the allroad - figured it was worth refurbing them with new seals and such to make them good and maybe worth something. Plus the 'fun' of doing them - never had one stripped right down before - maybe not worth the hassle if funky tools are required along the way.
          you need cranked long nose circlip pliers and a piston rewind tool helps. its a massive PITA to get the internal spring cage to seat properly without deforming, i'm sure there must be a special tool for it. You can replace all the seals easily bar the one on the handbrake lever, as this requires complete dismantling of the caliper. I swore never again! The best solution if you are going to do the job is tap a hole for a grease nipple into the handbrake lever bore that way you can top up the lubrication every time you service the car or whatever maintenance schedule you have - IIRC it was Rob GT500 who came up with this idea
            #20
            I like the nipple idea... unfort it is that damned seal on the handbrake mechanism that I need to fix from the allroad calipers - was leaking fluid.
              since they are a larger piston diameter they are probably "easier" to do as the piston bore is larger meaning more room to get in there to compress the spring cage. You are more than welcome to borrow my funky circlip pliers if you fancy giving it a go. Nothing to loose by trying really as if it all goes t1ts up you can just wind the piston back in and exchange them at ECP or wherever
                #22
                These are only 38mm - alloy version of B4Q caliper with a different hose fitment. I will have a look sometime - good tip on the oddball circlip pliers. Is the seal kit self explanatory or are there instructions somewhere ?
                  Ah! Then they'll be an equally large pain in the *****!. its all pretty self explanatory really mate
