What is the largest disc that can fit under the OEM RS2 cup1 rims/993tt calipers?
370mm disc too large for cup 1 17'' RS2 rims?
370mm aren't going to fit, they would be 18" only and I doubt the calipers could accept the disc without overhang.
Even ultimot.de rate the 350mm RS2 conversions as 18" only
330mm are a tight fight with 996 turbo calipers under 17" on an RS2 which is going to the max size you're going to be able to run IMO -
It does depend on the caliper too, as Jamo says, 370 is too big. I have 345mm discs inside my Cup 1's, but I do not have Porsche calipers...370mm aren't going to fit, they would be 18" only and I doubt the calipers could accept the disc without overhang.
ChrisHonda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
Thanks for the replies.. at the moment 370mm is the smallest PCCB disc Porsche makes as I can tell from searching. Trying to achieve a lightweight brake/rim setup so a huge caliper and disc is not for me because they'll have to fit nicely under the 17'' cup 1.
Any suggestions other than 993tt steel disc? Probably not the 17'' rim restricts much choicesCheers mis amigos,
_AntonComment
Would be nice to hear his experience on them.
I was hoping to lose some weight but I won't go larger rims to accommodate pccb disc as Id rather stick with 17'' mag rims which lose the more weight over all. Will update my thread once I get on further.Cheers mis amigos,
_AntonComment
Your disc is 14.5" under 17" rims.I fitted 360mm with 6 pistons giant calipers under 18" rims.I got 3-4 mm room
From the inner rims.one of a few I5 from Asia.Comment
