scary high speed moment
  • DamoM
    • Feb 2005
    • 352
    Originally posted by prj
    The reason the ABS warning light came on, is because your wheel seized and now the speed reading from that wheel was lower than from all the other wheels.
    Very simple.
    Check indeed for a mechanical problem. The bearings etc...
    Simple indeed but what would have caused the seizure? The bearings are fine which only leaves the cv joint. Garage are checking that now.
    *1986 ur quattro,2.5 stroker
    *1995 Nogaro Blue RS2,Md357
    *1991 RR 20v quattro
    *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
    • prj
      • Mar 2010
      • 6308
      Well, I am quite sure it's not your ABS.
      If you want, disconnect the ABS ecu or pull the fuse. I am almost completely sure you will have the issue re-occur.
      • DamoM
        • Feb 2005
        • 352
        I think you're right. I just don't want to actually test it as it's dangerous!
        • prj
          • Mar 2010
          • 6308
          Not if you drive sensibly
          EDIT:
          Oh... yes, driving with a such condition is dangerous.
          I thought you said driving without ABS is dangerous.
          Yes, I agree, you should not drive the car until the issue has been found.
          • driftin jo
            • Sep 2007
            • 2222
            Originally posted by WabTheKing
            did this have a split cv boot or anything? clicking on turns? or completly unprovoked?
            The CV boot wasn't split but when I took it apart all the ball bearings were loose inside the boot.
            The CV joint was making the characteristic clicking sound on full lock prior to the incident but I have heard worse than the noise it was making from other ones in the past. It is possible that one or more balls had come out prior to it letting go completely when I tried to reverse it up my drive.
            It has made me think about noisy CV's from then on as before this I never realised they could have
            done such dangerous thinks as pulling the steering one way suddenly. I would advise anyone with a noisy CV joint to change it asap.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #21
              that is indeed scary stuff..
              is there a specific amount of mileage that the cv joints should be replaced regardless?
              • spink
                • 4382
                I had a cv joint seize years back on an old belmont exact same as what you describe.
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  #23
                  PRJ is right...the ABS is designed to UNLOCK the brakes...not lock them...is locking the brakes at the cars with the ESP...to keep the car on the road..but RS2 dosint have that.
                  Is an CV joint or wheel bearing.
                  Scarry stuff...dont drive untill you find the culprit.
                  Regards!
                  Eugen
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    #24
                    As said previously, this has to be a mechanical problem, not an ABS electrical problem. How does an ABS unit generate brake pressure?
                    For some reason the outer CV's ABS ring isn't being picked up by the sensor, hence showing a fault. Either the CV is stopping or seizing, or it is moving away from the ABS sensor somehow.
                    SS
                    • prj
                      • Mar 2010
                      • 6308
                      It doesn't mean it's not being picked up.
                      It's enough if one wheel rotates slower than all the others to get an ABS fault.
                      • s2_wot
                        • Aug 2006
                        • 2178
                        #26
                        Could there be a fault with the diff lock switch or diff lock actuator. If the rear diff locked at high speed the car could go anywhere. Isn't that switch wired to the abs light on some cars.
                        Shane
                        • driftin jo
                          • Sep 2007
                          • 2222
                          Why ? The rear being locked would not cause the car to do anything drastic, just scrub the tires a bit in the corners.
                          The fact that he was on the gas at the time would mean the diff lock could not be engaged, you have to back off for the diff lock to engage and the electronic lockout would have to be disabled also as he was above 15mph me thinks.
                          • Acidburn
                            • 13459
                            Out of interest how much is a new cv joint for a s2?
                            • driftin jo
                              • Sep 2007
                              • 2222
                              About the same as the average down payment on a mortgage .
                              • Acidburn
                                • 13459
                                Ah sounds like the problem ppc magazine was having buying roller bits, came down to what part of upmarket london etc you could buy for each bit.
