Compbrake new standard rear caliper
This is a sticky topic.
  • Tonks4x4
    • Nov 2005
    • 3062
    Don't know if it's been covered, but Compbrake now do a replacement rear caliper for the rear of the S2 very cheaply indeed. I had a chat to one of the compbrake guys at the Autosport show and he assured me that you will not have any issues with any of their products.
    Audi Nut!!!
  • spink
    • 4382
    look very similar to the ones that custom auto craft do,they look to be based on the later mk4 golf/a4/leon/a3 design.
    • quattrostyle
      • Oct 2006
      • 6229
      2nd that, CAC does them with new pads AFAIK.
      • bluequattro
        • 2959
        I have an issue, mmy big expensive fron calipers from compbrake have both sprung a leak!
        Maybe through lack of use, need to take them off and see what compbrake can do
        • Jonnybravo
          • Aug 2008
          • 2051
          TBH the Compbrake stuff is just the same old bad quality TAS equipment. I'm not a fan.
          Hopefully the rear calipers are better than their fronts !
          • andy10v
            • 5996
            Compbrake;
            Custom Auto craft;
            Sold ABY-stock
              Chinese?
                I'd say they are... Price is not much better than getting exchange ones via GSF or ECP - but then we don't really know where all those come from either - ahh the global economy - makes for a world of confusion
                • andy10v
                  • 5996
                  If they don't seize up like the oem ones do then they could be nice, however if I am replacing the pair might as well go 280 disc with urs4 calipers etc.
                  Sold ABY-stock
                  • Mr.Crossfire
                    • 145
                    They do seize up eventually, but I think it'll take years. I have ran pair of those in my A6 tdi for a year now, in harsh Finnish environment (-20 C temperatures, salt, gravel, dirt, etc.) And for now they are holding up just fine. Recently installed another pair in my girlfriend's aby coupe. There is a pad fitment issue though. I had only slightly worn TRW pads & discs on the coupe, so I decided just to swap calipers. The TRW pad has higher mounting tab for the anti-rattle spring than the pads that came along the calipers (from CAC). So the tab hits the caliper, as the hole in those aluminum ones is a little shorter than cast iron ones. Hard to explain, but you can easily see the difference when you compare the calipers side-to-side. I just grinded the hole longer, I don't think that the caliper is going to deform anyway.
