Anyone any ideas as to what sort of money I would be talking for the repalcement of the ABS pump in my 3B? Have done masses of reading and I think I have concluded that my ABS issue must be caused by the pump.
When you start to move off in the car you can hear a pump engaging, definately coming from where the ABS pump sites. Red warning light flashes three times etc. If you disengage the ABS (optional switch) then the noise stops.
To insert a picture... click on the 'Go Advanced' button instead of 'Post Quick Reply' - then you will see for options to add attachments with a dialog box that will ask you to select the pics from your desktop.
