Hi everybody,
I have strange problem with my power steering. About one month ago, "!" sign appeared on check display when I start the engine, after few seconds disappeared, and everything is OK. I also noticed oil leaking on T clip numbered 15 on picture below:
I tried everything to stop bleading between hose number 14 and clip 15, but without results. I change two pipe clips, shortened the hose, but with no effect
After about 15 days, i noticed that time need to turn off the "!" sign is increased. Also, there is strange pedal movement when I start the car and pump the brake pedal, like ABS is turned on, but it disappeared after 2-3 pumps.
The biggest problem occured yesterday when I drove car for 3 hours on highway, i noticed "!" sign on the dashboard, stop the car, and there were oil leaking from bottle cap. Servo pump could be heard very loudly, as it is almost without oil. I tried to add some oil, but everything is dropped. Somehow, I returned home, and in the morning I add some oil in the bottle, start the car and everything is OK, instead of "!" sign for 10-15 seconds. I forget to mentioned that steering pump is always little noisy when I turned the wheels. Today, I also drive my car for a few hours, and the same thing happened again. It's like something is clogged into the hose, and oil is leaking from bottle cap, and steering pump is noisy, just like working without oil.
Also, sometimes I noticed that steering wheel is harder to turn left or right, but mostly everything is OK
Does anybody know what could be a problem? Power steering pump, bomb, both or something else
Thank You all in advance.
Best regards.
Best regards.
