S6 ABS help needed urgent
  • 220bhp
    • 2578
    • Home: United Kingdom
    Just put my s6 in for an MOT,and it failed on a few things.One was the ABS light on all the time,and they cannot get vagcome to read the ABS ECU.
    The light has been on since we welded the pedal box up after it snapped.
    We welded it up insittue.I have done a search for the ABS light,but with no luck,so I would be very greatful if anyone could offer any ideas.
  • Christophski
    • 3632
    Simple solution for an MOT is remove the bulb from the dash maybe?
    • Christophski
      • 3632
      Meant to say then do a proper fix afterwards to give you longer to fix it?
      • 220bhp
        • 2578
        I forgot to say that the red warning light is also on.
        • Christophski
          • 3632
          Ahh, I guess that doesnt help then. Mind you I know that when you get the warning symbol on the LCD display for Power steering if you disconnect the plug it goes away and leaves it alone. Is this the same with the ABS symbol? Worth a try? it is still worth fixing properly if you have the time as its a safety feature for you and the family.
            Was the welding done with an electric arc welder and one cable was grounded to the part of the pedal connected to the car, by chance?
            • 220bhp
              • 2578
              It was a mig welder ,and it was earted to the pedal box,
              • Kieron20V
                • Mar 2008
                • 1505
                Yeh, as urs4boy is suggesting, pretty sure in the bently it says to disconnect the abs unit whenever doing any welding, or some such precations.
                1994 URS4 Avant RS2+
                • 220bhp
                  • 2578
                  What damage would the welding of caused
                  • Kieron20V
                    • Mar 2008
                    • 1505
                    Frying is the generic term I believe, I dont know what, or why but theres plenty of sensitive elctronics in them black boxes....
                    Before doing any electrical welding on cars equipped with ABS, disconnect the battery negative (-) terminal (ground strap) and the ABS control module connector.
                    Maybe try another ABS control unit? I have a spare coupe one, dunno if its the same.
                    Have you checked fuses ??
                    • prj
                      • Mar 2010
                      • 6308
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        ABS light needs to come on and go off for the MOT you cant just take the bulb out
                        Chef
                        • Christophski
                          • 3632
                          Hmm then I'm screwed with my T4 next month
                          • Christophski
                            • 3632
                            I thought an abs light was an advisory until April?
                            • rs200
                              • May 2009
                              • 1398
                              • Home: Croatia
                              hahahha
                              Delboy & Rodnney style !
