Unfortunately an ABS light on or failing to light if fitted has been a failure for a few years.
S6 ABS help needed urgent
Fair enough. Looks like something im gonna have to fix on the van then. Still need to get it oput of limp mode too haha (So**ing thing)Comment
Thanks Chris,that will be my next corse of action.Unfortunatly I think the one of my 3b is different.
This has crossed my mind,but I cannot as yet find out how to check this.Comment
An S6 won't have the ABS relay with a fuse.
When they removed the ABS cancel switch from the dash, they also updated the ecu and other electrics and removed that relay.
I suspect the ABS ecu module may be damaged. I've got an old S2 one lying around which is the same.
You can have it for postage if you're stuck.Mike
http://www.s2-audi.co.ukComment
Thanks I might take you up on that.An S6 won't have the ABS relay with a fuse.
I went to the local breakers yard and there is a b4 a6 there it should have an abs ecu,
not sure where its located,is it the one under the back seat.Comment
Sorry!!!An S6 won't have the ABS relay with a fuse.
I didint know this!
Is strange..because i welded the entire tunnel from the car with the abs ecu there...and no issues... But i had the old s2 abs...with cancel switch... Sorry iff i gave you wrong info
Hope you sort this out!Comment
Certainly in the s2 it is under the rear seat.Comment
