S6 ABS help needed urgent
  • TimE-J
    • Jul 2009
    • 1292
    Unfortunately an ABS light on or failing to light if fitted has been a failure for a few years.
    96 S2 aby Coupe. Rebuild Project
    96 mk3 golf tdi daily.
    • Christophski
      • 3632
      I thought until now if the ABS light was on it was an advisory?
      • audinut
        • Jul 2009
        • 2195
        Originally posted by Christophski
        Simple solution for an MOT is remove the bulb from the dash maybe?
        If the tester is doing his job properly he has to check the operation of the light
        NOT a car dealer! just an S2/RS2 enthusiast
        • Christophski
          • 3632
          Fair enough. Looks like something im gonna have to fix on the van then. Still need to get it oput of limp mode too haha (So**ing thing)
          • 220bhp
            • 2578
            • Home: United Kingdom
            #20
            The battery was disconected,and the two connectors on the pedel box are both plastic,so how could damage occur,would not the fuses protect it anyway.
            • LHD_Kid
              • May 2006
              • 3697
              #21
              I guess, if you can borrow an ABS ECU then this would rule out any such damage?
              • bikerjim
                • Feb 2008
                • 1028
                Is there a switch on the pedal that is not set properly in the correct position? Just a thought.
                • 220bhp
                  • 2578
                  #23
                  Thanks Chris,that will be my next corse of action.Unfortunatly I think the one of my 3b is different.
                  This has crossed my mind,but I cannot as yet find out how to check this.
                  • Kieron20V
                    • Mar 2008
                    • 1505
                    #24
                    Have you got access to vagcom? If the light is on and the unit isn't dead you should have a dtc.
                    1994 URS4 Avant RS2+
                    • Pirvu Eugen
                      • Apr 2007
                      • 1978
                      • Country: Romania
                      #25
                      Have you checked the fuse from the top of the ABS relay?
                      10 amp fuse..
                      • 220bhp
                        • 2578
                        #26
                        [QUOTE=Pirvu Eugen;618434]Have you checked the fuse from the top of the ABS relay?
                        10 amp fuse..[/QUOTE
                        Where is the relay located on the S6.
                        • Mikes2
                          • 1704
                          An S6 won't have the ABS relay with a fuse.
                          When they removed the ABS cancel switch from the dash, they also updated the ecu and other electrics and removed that relay.
                          I suspect the ABS ecu module may be damaged. I've got an old S2 one lying around which is the same.
                          You can have it for postage if you're stuck.
                          Mike
                          http://www.s2-audi.co.uk
                          • 220bhp
                            • 2578
                            #28
                            Thanks I might take you up on that.
                            I went to the local breakers yard and there is a b4 a6 there it should have an abs ecu,
                            not sure where its located,is it the one under the back seat.
                            • Pirvu Eugen
                              • Apr 2007
                              • 1978
                              • Country: Romania
                              #29
                              Sorry!!! I didint know this! Is strange..because i welded the entire tunnel from the car with the abs ecu there...and no issues... But i had the old s2 abs...with cancel switch... Sorry iff i gave you wrong info
                              Hope you sort this out!
                                Certainly in the s2 it is under the rear seat.
