C4 UrS Front Brake Options
    Based on trying to find something that would help Shone190 with his brake situation, I updated a previous C4 UrS brake option post that I had done at my home forum. I am posting the link below. I am also asking to be "schooled" on Girling brake designations, e.g. G54, G57 and G60. I know that G60s are two piston calipers (that's what Audi gave us in NAmerica for the UrS4/S6 instead of the HP2s that the rest of the world got). I think I have G57s (?) on my 98 C4 A6 Avant (single piston, solid rotor, but I am not sure). Any help as to what a G54 or G57 is will be appreciated.
    Here is the C4 UrS4/S6 brake options link:
  • mcandmar
    • Apr 2004
    • 5118
    G60's on an S4, they are just about able to cope with the weight of an S2!
    Do you know how many variation of the front struts there are? Do the G60 cars use the same strut as a UFO or HP2 car? Basically what i am getting at is there an easy way to fit Porsche brakes to our UFO equipped S4 without having to change the struts.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • diesel des
      • 3896
      I made adapter carriers to fit Compbrake 4 pot Porsche copy calipers on urs4 struts. I'm using 345mm discs under 17 inch rims. Just clear and no more. Discs are less that 100 per pair and calipers with pads less than 300 new.
        C4 Wheel Bearing Housing info
        Originally posted by mcandmar
        G60's on an S4, they are just about able to cope with the weight of an S2! Do you know how many variation of the front struts there are? Do the G60 cars use the same strut as a UFO or HP2 car? Basically what i am getting at is there an easy way to fit Porsche brakes to our UFO equipped S4 without having to change the struts.
        Ha. I did not realize that the S2s came with G60s. The North American UrS4/S6s were speed limited from the factory to 130 mph (208 kph) (10 minute job to remove the limiter) so I guess they figured G60's will do.
        I have documented all the different wheel bearing housings (aka uprights, front struts, etc) in this post from the long version of the UrS Systems and Chassis "Map":
        Wheel Bearing Housing 101:
        UrS System and Chassis Map - long manual version (links under diagram)
        Short active version (links *IN* the diagram, click on the label version):
        Apikol might make the caliper mount that you seek.
        • mcandmar
          • Apr 2004
          • 5118
          Ugh too many options. Either way it looks like custom brackets for whatever calipers i can get my hands on. Pity there isnt a cheap and easy easy bolt on solution.
            There was a solution. BIRA had a UFO conversion bracket back in the day (circa 2000). BIRA is dead now.
            • merlin's S4
              • Jan 2005
              • 1539
              Somebody here documented drilling and tapping the ufo strut to take the HP2 caliper. If that works then I'm sure something could be done with the Cayenne caliper or perhaps with an RS2 bracket and 996 calipers ala the common S2 conversion.
                I searched the forum on "UFO conversion" and pulled up a few threads. One with talk about replacing the UFOs with HP2s was posted by Craigs4 but there were no actual photos of the completed project. There was a correction on the rotor size (314 x 30, not 323 x 30):
                • saltinot
                  • May 2004
                  • 1946
                  Personally, I like this idea. HP2 to Cayenne
                  Fitted New Cayenne Calipers on UrS6
                    Yeh, that is why I included Pop's DIY in the revised C4 Brake options post yesterday.
                    The major downside (IMO) of the Cayenne brake option is the need for 18" (or 19") wheels to fit over the caliper/rotor combination.
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      Cayenne 955 calipers is good to go with HP2 struts too.Everything is just bolt right up.They require the 350mm not 360mm rotors plus some metal bushings on the mounting bolts to align the caliper to sit at center of the rotor discs.All I need to do is grinding the rotor down to the matched size.
                      Write up will be posting soon once i finished everything.
                      one of a few I5 from Asia.
                      • merlin's S4
                        • Jan 2005
                        • 1539
                        With the correct Cayenne/VAG caliper over a 330mm disc 17" alloys can be used.
                        • Hammu
                          • 84
                          What is the offset on your rotors?
                          • popdemonic
                            • Dec 2007
                            • 1304
                            • Country: Thailand
                            overall height is 59,4mm,the stock 314X30mm rotor is 58,4mm. 1mm differences no big deal.
                            • rst
                              • May 2006
                              • 102
                              I'm using VW Touareg 4 piston calipers.
                              Hello there Touareg owners. I am wondering if someone can clarify for me (visually too), the differences between the 1LE and 1LC calipers found on the front of the Touareg. I understand the 1LE is 2007 (including some 2006) and above, for 330mm rotors, and that the 1LC is 6 piston for 330mm...
                              They fit PnP to UrS4/S6 without UFO calipers models. All you need is just (17 or 19mm long, dont remember anymore, it was two years ago) metal bush to center the caliper to the rotor. I'm using 323x30 or 323x32 A8/S8 rotors (dont remember this anymore either).
                              Audi UrS4 609hp/846Nm @ wheels
                              10.911@210, 1km 268km/h, 1mile 295km/h
                              FATS 2,30 sec
