Recently,I just fitted the new 6 pistons Cayenne Calipers on HP2 strut UrS6.
I use 360mmX34mm from later A8 or S8 IIRC on my car.There's ~1mm overall height differences compared to stock 314X30mm rotors.They fitted perfectly.
the calipers is huge.They have approx.40cms in lengths.
same mounting distance,need 16 mm bushings to slide in the calipers to be on
the center aligned of the rotor disc.Needs some small grinding on the strut and the brackets to clear the Cayenne brackets.the rest is just bolts right up.the only problem
i noted is the brake pads has 70mm in sliding face width while the rotor has on 65-66mm so you need to grinding some of the brake pads off.I spent $75 for reprayed the calipers in gallardo orange, grinding job,4X of 16mm steel bushing,fittings.
They look nice under 9"X19" RS6 rims with 235/35R19 but finally,I roll back the thing
to 18" with genuine BBS LM.this's my dreaming wheels.they are 9X18" all 4.
front ET is +42(Flat dish) and Rear(Deep dish) ET is +40.the front rims is clear the calipers.There's 13mm room between spokes and calipers.i'm looking to buy 9X19"
BBS LMs too.I will post an updated when they're arrived.
