Fitted New Cayenne Calipers on UrS6.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    #76
    Originally posted by Wizard-of-OD
    Great write up!
    This part is a little confusing. These are
    Porsche Panamera / late Cayenne Turbo S calipers (4.8 V8 NOT 4.5 V8 which came with the 19Z's). They are larger than 18Z's so not exactly the same.
    These are the part #'s
    955-351-421-70
    955-351-422-70
    Not without adapters.Both 18Z & 19Z use a 146mm Centre to Centre on the axial mount
    Same goes for B8 S4/S5/RS4/RS5 so if your C6 has a 146mm centre to centre then you can use them.
    HTH
    Issam
    Yes the calipers were taken from 957 Cayenne 4,8 V8...
    Thanks for the correction.maybe i'm confused between the number from Porsche PCD which has 5x130mm. I have HP2 struts and any Porsche big chassis with axial(side) mounts is bolt right up.
    one of a few I5 from Asia.
      C4 UrS Wheel Bearing Housing and Front Brake info
      Issam/Wizard: In case you didn't know this, all the Canadian/US C4 UrS4/S6s got Girling G60 front brakes on "special" wheel bearing housings. In the rest-of-the-World (ROW), the UrS4s started out with "UFO" front brakes on unique wheel bearing housings. By some time in 1993 model year, there was a switch to the "HP2" calipers on yet again a third C4 UrS wheel bearing housing, not found in NAmerica (unless specially imported as a part). The HP2 brakes and their associated wheel bearing housings were then used on the 94 UrS4s and the 95-97 UrS6s in the ROW. This is the wheel bearing housing that Pop has on his UrS6 in Thailand.
      More C4 UrS Front Brake info here:
      Wheel bearing housing info:
      • Wizard-of-OD
        • 926
        • Home: Syria Current: Canada
        #78
        Not disputing that. Just stating that the bolt centre for the 18Z caliper or Cayenne/Panamera is 146mm. He posted 130mm.
        Issam N. Abed
        iABED Industries
        iABED Email | Facebook
        The build thread
        • Thuppu
          • 4115
          Thomas,
          i believe you could use stock brake hoses if the length
          is enough when turning the wheel lock to lock.fortunately,
          i have a pair of old SS goodridge from a nissan 350z.i had them on
          urs6 and worked well.
          Did bought HEL's Golf mk2 to Brembo braided hose kit. They seems to be 450mm in lenght with a nice 90 degree elbow on the caliper side. Hope they will be good...
          • UrS6 - IamS6
            • Nov 2014
            • 148
            • Home: Ireland Current: Western Sahara
            #80
            Photos when you are ready.
            Thanks.
            • marius555
              • Apr 2012
              • 126
              • Country: Romania
              #81
              Dear friends ,
              I just installed this setup. It was really plug&play
              A bottle of "palinca" to Popdemonic !
              • marius555
                • Apr 2012
                • 126
                • Country: Romania
                #82
                Also i have done a little weight test ....
                • A1QSHIP
                  • Aug 2004
                  • 975
                  Yes but how much of that weight loss was added back by the larger rotors? It might shock you to know.
                  "Nulla tenaci invia est via"
