Fitted New Cayenne Calipers on UrS6.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    Recently,I just fitted the new 6 pistons Cayenne Calipers on HP2 strut UrS6.
    I use 360mmX34mm from later A8 or S8 IIRC on my car.There's ~1mm overall height differences compared to stock 314X30mm rotors.They fitted perfectly.
    the calipers is huge.They have approx.40cms in lengths.
    same mounting distance,need 16 mm bushings to slide in the calipers to be on
    the center aligned of the rotor disc.Needs some small grinding on the strut and the brackets to clear the Cayenne brackets.the rest is just bolts right up.the only problem
    i noted is the brake pads has 70mm in sliding face width while the rotor has on 65-66mm so you need to grinding some of the brake pads off.I spent $75 for reprayed the calipers in gallardo orange, grinding job,4X of 16mm steel bushing,fittings.
    They look nice under 9"X19" RS6 rims with 235/35R19 but finally,I roll back the thing
    to 18" with genuine BBS LM.this's my dreaming wheels.they are 9X18" all 4.
    front ET is +42(Flat dish) and Rear(Deep dish) ET is +40.the front rims is clear the calipers.There's 13mm room between spokes and calipers.i'm looking to buy 9X19"
    BBS LMs too.I will post an updated when they're arrived.
    one of a few I5 from Asia.
  • Nero
    • 347
    Monsterly great brakes!
    Nice wheels and car also.
    www.S2power.com
    S2 Coupe - decat - EPS exhaust - RS2 IC - RS2 front - RS2 brakes - RS2 mirrors - Koni shocks - H&R springs - Jehnert doorpanels & Audison Amps - leather & sunroof - VEMS - USA rearlights
    • Skull
      • 3506
      • Country: Slovenia
      Audi Quattro WR
        Christ! those are the new style calipers with the flex bracing, very nice
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Jamo,firstly I'm going to have NISSAN SKYLINE R35 GT-R calipers on my cars.
          after i have digged up more infos and i found that HP2 strut having the same 130mm
          mounting distance like 955,957 cayenne so I followed this route.
          • Bram
            • Aug 2006
            • 2582
            Phat car dude! I like it
            • s2_bo
              • Oct 2005
              • 6067
              Thats big alright! Makes the RS6 8 pots look like toys..
              Am i correct in thinking you didnt have to fabricate any special mounting brackets to fit these as he HP2 struts have the right spacing?
              91 S2 coupé - RIP
              98 S8 - Luxury barge
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                Yup Bo,all you need to do is grinding/cutting some of the square pieces on the HP2 struts and on the Caliper brackets.I used the stock caliper bracket which has the 130mm mounting distance same as the HP2's.:mischeif:
                • quattrostyle
                  • Oct 2006
                  • 6229
                  that looks great, and I bet the stopping power is great too.
                  I got a set of these calipers that are no use to me...
                  • s2_bo
                    • Oct 2005
                    • 6067
                    Would you mind posting the caliper part numbers
                    91 S2 coupé - RIP
                    • URSIMPO
                      • Jul 2008
                      • 431
                      Wow
                      • s2_bo
                        • Oct 2005
                        • 6067
                        you want to let me have them then??
                        91 S2 coupé - RIP
                        • s2_wot
                          • Aug 2006
                          • 2178
                          part numbers
                          they should be the red ones listed at the bottom of the page on this link:
                          Looks like amazing stopping power
                          Shane
                          • Big Lee M
                            • 2571
                            Wow, on the last picture the car looks amazing. I love the BBS LM's they suit the car. I bet it stops on a button.
                            Just some finishing touches to do now
                            • popdemonic
                              • Dec 2007
                              • 1304
                              • Country: Thailand
                              The pistons size is 36mmX6 on the calipers.I have not had the rear calipers on my car yet because i'm looking
                              to the way to put the handbrake on.surprisingly,the i think this calipers had ended up with better brake bias compared to stock HP2 calipers.
