Fitted New Cayenne Calipers on UrS6.
  • Thuppu
    • 4115
    Thanks pop!
    I was going to buy 17Z calipers, did call about them, but then waited too long and someone else did buy them. So I panict and did take the 18Z that was the same price.
    I can make any modifications to the strut fittings if nessesary, but fitting under the 17" wheel isn't needed, all my wheels are 18". Only my winter and ice track wheels are 16" so have to forget about them now.
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      #62
      if you re not having problem running the 18" rims,18zr ain't your problem then Thomas.
      the rest is much easier than you fabricated the swirlpot
      one of a few I5 from Asia.
      • Thuppu
        • 4115
        Yes, need to buy new winter tyres, 17" could be cheaper, but then I have to get new wheels for them. I will just look at 18" tyres...
        • Wrath
          • Jan 2011
          • 779
          Have Pm´nd you Thomas, starting to get back to reality so I can go on with my car and of course the porsche brake setup !
          1995 Audi S6 - AAN (~350hp)
          2008 BMW 530xd (235hp)
          2011 KTM 990 SMR - custom tuned (120whp)
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            #65
            Hello Goeran,
            let's update your thread mate i remember
            you have sn alternative solution on front brake setup.
            and doesn't need to resize the discs iirc.that's cool.
            • Thuppu
              • 4115
              Btw pop, what brakeline hoses do you use?
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                #67
                Thomas,
                i believe you could use stock brake hoses if the length
                is enough when turning the wheel lock to lock.fortunately,
                i have a pair of old SS goodridge from a nissan 350z.i had them on
                urs6 and worked well.
                • Wrath
                  • Jan 2011
                  • 779
                  Pop:
                  Yes my intention is to do something like this as soon I get well enough to begin. It´s worktraining and rehab that´s on focus for the moment.
                  Had almost them done in MDF wood before the incident with my back, so when they are ready I´m gonna leave them to my friend that work with CNC so I can have them in billet aluminium or steel.
                  Then you will have a caliper that sits straight instead of bent and you don´t need to rezise down the disc or pad.
                  • dustovich
                    • May 2014
                    • 50
                    What strut cartridges do you have?
                    • Wrath
                      • Jan 2011
                      • 779
                      HP2 euro style...
                      • dustovich
                        • May 2014
                        • 50
                        Those look a lot more robust then the american versions , especially with that reservoir. Sorry to hijack.
                        • Wrath
                          • Jan 2011
                          • 779
                          That just some picture I took from the internet, they will look kinda like that but bigger and more robust.
                          • joedredd
                            • Sep 2014
                            • 1
                            Gents I wonder if you can confirm if the 18z calipers will fit straight onto my C6 A6 3.0tdi avant.
                            My current disc size is 347 x 30mm. Do I bolt them onto my existing carriers or straight onto the hub?
                            If not a "plug n play" unit, what mods are needed to make them fit?
                            Is it best to get the larger disc or can I stay with existing disc?
                            Sorry for all the questions for my first post, but I hope this will make the braking better.
                            George
                            • popdemonic
                              • Dec 2007
                              • 1304
                              • Country: Thailand
                              #74
                              George,
                              you need to try to measure the caliper mouting distance on the strut if yours is 130mm IIRC.
                              if yes,you probably can fit 18zr calipers.
                              • Wizard-of-OD
                                • 926
                                • Home: Syria Current: Canada
                                #75
                                Great write up!
                                Originally posted by popdemonic
                                1.18ZR/ZL from 955 Cayenne S or Turbo.only differences between these caliper is finished color..
                                This part is a little confusing. These are
                                Porsche Panamera / late Cayenne Turbo S calipers (4.8 V8 NOT 4.5 V8 which came with the 19Z's). They are larger than 18Z's so not exactly the same.
                                These are the part #'s
                                955-351-421-70
                                955-351-422-70
                                George,
                                you need to try to measure the caliper mouting distance on the strut if yours is 130mm IIRC.if yes,you probably can fit 18zr calipers.
                                Not without adapters.Both 18Z & 19Z use a 146mm Centre to Centre on the axial mount
                                Same goes for B8 S4/S5/RS4/RS5 so if your C6 has a 146mm centre to centre then you can use them.
                                HTH
                                Issam
                                Issam N. Abed
                                iABED Industries
                                iABED Email | Facebook
                                The build thread
