Hello there Touareg owners.
I am wondering if someone can clarify for me (visually too), the differences between the 1LE and 1LC calipers found on the front of the Touareg. I understand the 1LE is 2007 (including some 2006) and above, for 330mm rotors, and that the 1LC is 6 piston for 330mm...
They fit PnP to UrS4/S6 without UFO calipers models. All you need is just (17 or 19mm long, dont remember anymore, it was two years ago) metal bush to center the caliper to the rotor. I'm using 323x30 or 323x32 A8/S8 rotors (dont remember this anymore either).
