Bomb rebuild
    Bomb rebuild
    Anyone got any recommendations for a place that can rebuild my dead brake bomb to as new condition?
    Or any pointers where can i get a new Febi unit? CAC don't seem to have them any more
    Alex
  • Matas
    • 35
    • Country: Lithuania
    Haven't considered about upgrading to vacuum?
      What’s involved on an ABY, and is it worth it, compared to having a fresh bomb and power steering pump ?
      Thanks.
        not interesting in switching to vacuum right now, just after some info on a new/refreshed bomb
        • bikerjim
          • Feb 2008
          • 1028
          If you have a FEBI part No. your local andrew page may be able to track one down for you. If you have the No. post it here as mine might be on its way out
            Thanks for the tip, I've got the number at work so I'll post it up tomorrow
            • PeterS
              • 423
              http://sites.google.com/site/audicqturbo/audibomb cost will negate impact the roi
              Peter S
              1990 ErsatzS2 - track toy
              1991 Coupe Quattro
              1991 Coupe Quattro
              1995 S6 Sedan
              1995 S6 Wagon
              • Matas
                • 35
                Thanks.
                My friend upgraded to A8 brake booster, and says that now brakes respond much better. I have one on my A200, but I had almost dead brake bomb. You need, a brake booster from A8 with to diafragms and to disable the piping for power steering pump
                • benntenn67
                  • Jun 2009
                  • 859
                  Alex
                  Hi Alex, This company can do it, well respected in the citroen community -Give them a call as they don't run a website
                  Pleiades <<Citroen Hydraulics>>, 01487 831239, 01487 832444, sales@ citroenspares.net, 20 Glatton Rd, Sawtry, Cambs, PE17 5SY, UK
                  Audi S2 Coupe 1995
                  VW Passat GL5 (hatch) 1986
                  VW Passat GL 1.8 (saloon) 1986
                  Carrera Subway 8
                    Thing with vacuum brake assistance is.. I'd worry the shi££y one way valve goes wrong and the servo gets 2 bar of boost instead of vacuum, would not be pretty..
                      Perfect thanks mate. I'll give them a try
                      I will go vacuum one day, probably once my engine is done. Its just too much messing about at the moment, I've got enough to think about right now
                      • rotoryboy
                        • May 2004
                        • 3281
                        You could probably ask if they can do us a group deal as I am sure there are a few of us in need
                        Mark
                        Race Clio RS197
                        S2 Coupe ABY (Green) - RIP
                        S2 Coupe ABY (Blue) - Sold
                          ok I'll try and sort out a forum discount as our "preferred supplier"
                          • driftin jo
                            • Sep 2007
                            • 2222
                            You could always use 2 or 3 one way valves in series if you paranoid about it, I think I would use 2 just to be on the safe side if I went to vac assist, either that or use a separate vacuum pump altogether.
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              a new on at audi cost around 800€ ?
