Does anyone know of a large master cylinder(larger then std 25.4mm) that would fit a S2?. A bit to much pedal travel with Cayenne calippers so need 27mm or larger.
Large S2 master cylinder
I thought Ben ( S2avant ) looked into this when he first fitted 8pots to his car and found that all the new Audi's with multi piston calipers still only used a 25.4mm master cylinder?sigpic
1976 RD250E / 350LC cafe racer -
There's two part numbers for the LHD RS2
The common RHD S2 and LHD RS2 master cylinder is part number 441 611 021 B
On the LHD there was another master cylinder 4A0 611 021 C for the 95 cars.
The 2nd one is bigger according to Jade who had them bothComment
Different part nr. , but same size cylinder:
In Norwegian, but states 25,40 for both part numbers.Attached FilesLast edited by Audi_CQ; 6 April 2012, 20:34.Comment
Hopefully still on topic,
Wir bieten sportlichen Fahrern erstklassige Produkte: gelochte Sportbremsscheiben, Bremsen-Umbauten, Stahlflex-Bremsleitungen, Motor- und Chip-Tuning
So does that mean that if one bought the Audi S2 BK650 kit, (365mm disc), the brake pedal would be much closer to the carpet ?
Btw, does anyone have the part numbers for the disc and the caliper in this kit and what Audi car it comes on as oem kit ?
Is it not possible to change a rod or piston in the brake cylinder to make it longer to change the length of travel required for the brake pedal ?
food for thought
ChefComment
it is the amount of fluid displaced by the master cylinder, lines won't make a difference. If you calculate the area of each piston then you see how much further the master cylinder has to travel to move the caliper pistons the same distance with big multi-pot calipers.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
of course . you are right.it is the amount of fluid displaced by the master cylinder, lines won't make a difference. If you calculate the area of each piston then you see how much further the master cylinder has to travel to move the caliper pistons the same distance with big multi-pot calipers.
now I take a look in ETKA and there is the same cylinder for
S2 (3b,aby) 25.40mm even the 7A have the same
s4 ,s6 - 25.40x13/22.5
,RS2 - 25.40x13/22.5
200 20v - 25.40x13/22.5
audi V8 - 25.40x13/22.5
they all are the same, and have same code. only 7a have different.Comment
