Cayenne calipers on UrS6
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    I think i shuld have posted this for anyone who having the HP2 struts.
    it's easy but take time if you're doing alone since everything is heavy.
    It took 15.00-21.00 fitting the Cayenne Calipers on my UrS6.
    that's really tired to do this alone.
    -Resized the rotor down from 360 to 352mm.
    -Machined 16mm steel bushings to make the caliper sitting right on the center of the rotors.
    -Goodridge SS brake lines.
    -EBC brake pads(taken from V6 3,2 Cayenne 955)
    -Cayenne S 4.5 Calipers.
    -Dot 4 Brake Fluid.
    -converted Porsche to Audi pad wear connectors.
    -22mm extra longer bolts for Caliper Brackets.
    -Grinding slightly inside of the calipers to clear the rotors.
    -Lot of patience.
    paid 30bucks for all grinding jobs(rotors,calipers,steel bushings.
    one of a few I5 from Asia.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    This's my last one..
    FYI.
      What’s the red caliper from ?
      Was it the caliper or the wheel that caused you to take the disc down from 360mm to 352mm ?
      Are the red and the silver calipers very heavy ?
      Torn between the lightness of Highspec alloy calipers / alloy bell and disc
      versus
      Large chunky looking brembo Porsche caliper and heavy discs or the new R8 type factory floating discs.
      Thanks.
      • s2_bo
        • Oct 2005
        • 6067
        That red caliper is also from the Caynne, but the 2010 model. Its a beast!
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          the reason i resized the rotors down since I'd rather to keep everything simple as much as possible.I can fit the Cayenne S calipers(Silver) with 360mm discs but I need to grinding asymmetrically on steel bushing in oval shape to make the calipers stick farther out a bit for the bigger diameter discs.
          Yes as Bo said the red calipers were taken from the 955 Cayenne 4.8L.It's the last model before the 957 launched out.the 957 will be using similar calipars.
          they use the same calipers as you've seen on Panamera 4.
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            another thing both calipers can fit with 360mm under 18" Rims LM.
            • Wrath
              • Jan 2011
              • 779
              whats the difference in using the 18z or 17z ? except disc sizes? are they 17z bolt on?
              1995 Audi S6 - AAN (~350hp)
              2008 BMW 530xd (235hp)
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                nothing.18zr has wider sliding face on the brake pads(72mm) while17Zr has 62mm.Anyway,they're interchangeably.you just stick with 17ZR pads since it's much more easier to sort out the rotor discs.
                • Wrath
                  • Jan 2011
                  • 779
                  Any suggestion of brake caliper choise in this matter? Whats the easiest way and cheapest to have big rotors? I have read something about 17zr calipers and merc 330 discs that you bore the center... almost plug and play except that you need some distans of some sort for the calipers.
                  They will go under 17" i presume, how about 18zr and 345 will they clear 17" ?
                  Have 19" summerwheels and 16" on winter but thinking of changing to 17" at least... 18" are almost to expensive when you want good winter tyres
                  • popdemonic
                    • Dec 2007
                    • 1304
                    • Country: Thailand
                    345mm will be clear the 17" but not all.You need to verify that.I have seen that Huge red calipers with 360mm under 17" rims.
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      personally,if you need summer tyre.330mm disc from Merc is your best bet or get some bigger disc from Audi and resize it down.
                      TTS rotors have 345mm but not sure about the overall heights.it they're similar or even closed let's say 1-3mm then you should be fine
                      to go with that.
                      • geryS2
                        • May 2006
                        • 814
                        • Home: Belgium Current: Portugal
                        my god, that s huge !
                        which size minimum do you need for the wheels ? does that fit in 17 " ?
                        S2 's and oldtimers
                        • popdemonic
                          • Dec 2007
                          • 1304
                          • Country: Thailand
                          It's probably fit under 17" Rims.Never tried it tho.I only have 16,18,19 rims.
                            345mm dont fit under 17" not enough caliper clearance for thermal expansion
                            • JP
                              • 1858
                              The Zr and zl 17's fit with 330's under the 17" rims. The zr and zl18's fit under 18's+
                              UrS6 Stroker + HTA3586 =
