little help with brakes please!
  • AQTdriver
    • Jan 2011
    • 750
    ok so as per title - problem with my brakes on the s2 avant is - car seems to be doing it for me - if say i stop at a junction and the n pull off the brakes will still be on but if i hit the pedal hard they are released... now i can't find much on the forum about this but one thing i did find was the servo...
    anyone had the same problem?
    regards!
    '93 S2 Avant breaking
    '95 S6 Avant sold
    '83 80 Quattro SWB
    '85 90 Quattro
    '85 200 Quattro 10V sold
  • AQTdriver
    • Jan 2011
    • 750
    Just to add - this started after brake upgrade... :/
    '95 S6 Avant sold
    '83 80 Quattro SWB
    '85 90 Quattro
    • BRY
      • 3755
      Which upgrade?
      • AQTdriver
        • Jan 2011
        • 750
        Well the front - rs6+ c5 and rear porsche 4 pots with 330mm...
        '95 S6 Avant sold
        '83 80 Quattro SWB
        '85 90 Quattro
        • AQTdriver
          • Jan 2011
          • 750
          Anyone?
          '95 S6 Avant sold
          '83 80 Quattro SWB
          '85 90 Quattro
          • Monkeymagic
            • Mar 2012
            • 3419
            Master cylinder sticking. Pedal box damaged?
            • Colesy
              • Feb 2009
              • 2980
              There aren't many people on here with RS6 fronts so probably not many people who can help with exact experience. But there are lots of problems with the front 996 upgrade due to lack of lubrication. One of the most common is when pads seem to stick and cause a resonating which stops when the pedal is dabbed. This can be fixed by using Ceratec brake lubricant like this, making sure all the runners are smooth and unlikely to cause sticking is important too.
              Good luck getting it sorted.
              • AQTdriver
                • Jan 2011
                • 750
                thanks, well i think it's unlikely to be the master or pedal box..
                it could be the pads sticking but i'm not sure about that as all wheels are doing it
                i was reading about the servo seals - if they are damaged the ''bomb'' can then apply pressure and that's what's causing it...
                well i will see if i can check the servo the way a few people have mentioned on here and then see what is what...
                thanks for the help guys!
                '95 S6 Avant sold
                '83 80 Quattro SWB
                '85 90 Quattro
                • s2_wot
                  • Aug 2006
                  • 2178
                  I'd look for a seized rear caliper or seized rear caliper guide pins or seized rear caliper hand brake cables.
                  Shane
                  • AQTdriver
                    • Jan 2011
                    • 750
                    all parts are virtually new so unlikely..
                    handbrake is hydraulic..
                    regards!
                    '95 S6 Avant sold
                    '83 80 Quattro SWB
                    '85 90 Quattro
                    • AQTdriver
                      • Jan 2011
                      • 750
                      ok so i had a little look today and changed the master cylinder for another second hand one but one i'm 100% sure it's ok... - still the same so i'm guessing it will be the servo...
                      i shall try changing that tomorrow and see what happens...
                      i'll keep posting to make it easier for someone else in future...
                      '95 S6 Avant sold
                      '83 80 Quattro SWB
                      '85 90 Quattro
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        I'm just guessing here. Did you crimp the flexi lines when changing calipers? Have seen this done where it crushes the internal of the hose causing poor flow/return of the fluid.
                        f brakes bleed easy then it is unlikely. Did you try freeing up the pads in the carriers etc as suggested. Could be simple as that.
                        • AQTdriver
                          • Jan 2011
                          • 750
                          Nope the flexis are ok and it bleeds fine..
                          Pads are moving ok too...
                          Thanks!
                          '95 S6 Avant sold
                          '83 80 Quattro SWB
                          '85 90 Quattro
                          • AQTdriver
                            • Jan 2011
                            • 750
                            Ok well today finally got around changing the servo.. Much to my surprise it went very smooth...
                            Everything is back together and brakes are perfect!!!
                            Hope this helps someone with the same problem! No actually I hope nobody will ever have this problem
                            '95 S6 Avant sold
                            '83 80 Quattro SWB
                            '85 90 Quattro
                            • Sleeper_Avant
                              • 2372
                              i see this a lot with modern crap, especially jags
                              glad you sorted it
                              1993 URS4 Avant Emerald Green 350+bhp
                              1991 Ford Sierra Sapphire 4x4 in Magenta
                              BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
