when braking today, more noticeable at slower speeds, it felt like the brakes were pulsing and felt as if they were coming on and off (not abs...)
I have 1 abs sensor playing up, could this be the cause? I'm going to give them another good bleed but with the MOT next friday and today my last day working on it before then, i'm at a bit screwed!
the porsche 993 brakes were immense though, stopped very quickly!
thought i'd clear this up a bit!
Symptoms
under braking, the car brakes in a straight line but jerks with hard and soft braking
has had a few abs errors with sensors but all currently working
Whats been done:
all brakes rebuilt - new seals etc
993 front brakes
re-bled several times - no air present
all pads are new
rear discs are new
front discs are skimmed (with in tolerance as far as i know, will check)
I've tried driving the car with ABS disabled and there was no change in the symptoms.
Symptoms
Whats been done:
993 front brakes
all pads are new
rear discs are new
might have to take a long drive to the MOT centre and see what happens.
