800 mm is each line but for fronts only ( I never did the rears so not sure about them).
The original drawing im my pervious link which I scribbled over was for 2 separate lines on the front and retaining the existing hard line on the strut, They are 300mm + 315mm and the part replacing the hard line on the front struts is in a loop close to 200mm. So 800mm overall including the fittings. This could probably be a bit less if the change in direction at the strut was a bit sharper.
For the rears (& fronts) you can check by taking a wheel off and running a string around the stock line route and measure the string. But remember the 996's connection is further down than the stock S2 callipers.
