Hi everyone,
Last year I did upgrade from UFO to 993TT with 323*32mm discs and EBC redstuff pads and HEL braided lines. I did the bedding procedure and I have to say that fortunately they brake better than my old UFO's.
However, I do think that the braking power is not as hard as I expected it to be. Maybe I'm wrong to compare it to new braking systems but if I compare the braking of my big reds with the one I have on a simple ford mondeo (2.5tdi) or a simple ford fiesta, those brake better!
I mean in the newer cars I own when you push a little too hard on the pedal you get your head knocking the steering wheel as the braking is hard. I had the same thing when testing the A7 3.0tdi. you push a little to hard at low speed, the car stops instantaneously and you break your head on the steering wheel.
I really don't get the same feeling with my 993tt calipers. I have to apply a reasonable amount of pressure to feel the brake.
FYI : I did change the steering fluid and the brake fluid (ATE super blue). I don't have spongy feeling. The bomb, steering pump and master cylinder have the same mileage as the car (425000km)
So I was wondering if :
It's normal ?
The pads/disk pair still needs more bedding?
Something is wrong in the braking circuit? can the bomb/steering pump/master cylinder influence this feeling?
Many thanks for your answers!
hugokx.
It's normal ?
hugokx.
they are one of the best I've every used with the porsche calipers on these cars....
