Brake lines for fitting alloy S8 rear calipers to S2 coupe
I'm going to be fitting these next week and was going to order some custom brake lines. Does anyone have the specs for the lines I need, length is the main thing I need to know but if someone had the full specs from their install that would be ideal.
They're the W4D0 615 423 E & W4D0 615 424 E calipers with the funny brake line caliper connection as pictured here:
I do have the original S8 lines as pictured but they look tired.
it was something I had to sort when I had braided lines made for mine as Goodridge don't do end fittings at M12.....if your thinking of using standard lines, you'll be fine...
