So I'm on the search for new rotors/pads all around (first time I've had to replace). Searching for S2 5x112 hubs with 993tt big reds on CQ over here in the states is proving a joy.
Currently I've got drilled Porsche OEM rotor rings/custom hat on the front and solid stock S2 rotors on the back. Don't know what pads I have (shop is doing the work, no place for me to work on at the moment)
SO far I've concluded I'll need to order the 993tt rotors and swap hats. Part numbers 993 351 045 10 and 993 351 046 10 (cheapest @ $230/ea!) or could go with A8 solid rotors (4D0615301J at 1/3 cost). I know the drilling is more cosmetic than function... but damn they look nice.
In searching for the rear rotors I came along an A4 rotor 8E0 615 601 (A/B/P, P being the most current) solid rear that should match the 5x112, 245x10 30mm hat, BUT also located some Zimmermann Sport Cross Drilled 8E0 615 601 BSP.
Anyone have experience with these? Not cheap at ~$80 a side. All this sound right to those with similar setups? Returning wrong rotors won't be an option.
Nice write-up on QW I found too
