Talking to the ABS ECU
  • philj
    • Feb 2010
    • 377
    Have 2 b4's with abs faults, lights on and the abs is off. Got vagcom which works on the later b4 tdi, but doesn't work on the early tdi or the coupe. I say works, it does most except it can't connect to the abs ecu.
    I tried one of those snap on jobbies with the massive buttons for fat mechanics hands, which read the faulty codes on the coupe but again wouldn't connect to the abs ecu.
    Is there a computer that'll work with these older ecus?
  • Smiley
    • Jun 2005
    • 329
    I would suggest you try to eliminate the possible reasons first, check the fuses, measure the wheel sensors, and so on..
    maybe you want to change the abs ecu, but that would be my last try..
    just my 2 cents
    '93 Audi S2 Avant panthero black, 412.000km
    '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
    '93 Audi S4 C4 Avant, 260Tkm
    '88 Audi 100 Avant turbo 44Q
    '84 Audi 80 quattro tornado red
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      I agree..check the fuses first.
      1996 S2 ABY Silver
      • ManiacuV6
        • Dec 2009
        • 458
        • Country: Romania
        What diagnostic tool did you use ? What is the part number of the ABS ECU (is under the back seat/passager's side ).
        Audi S4 2.2T 5 spd 1992 for parts
        AUDI A4 1.9TDI daily use
        Audi 80 Quattro 2.0 16V (ACE) aka Competition
        • philj
          • Feb 2010
          • 377
          Just vagcom, but also tried the snapon solaris jobby and neither of which worked, but as I said vagcom doesn't seem to connect to the earlier cars anyway. Anyone else had any success with vagcom?
          • ManiacuV6
            • Dec 2009
            • 458
            • Country: Romania
            Vag Com is a good tool but depends which version you have. If you don't have supply to the ABS ECU is something normal to not be able to connect.
            Try and check the fuses !
