Have 2 b4's with abs faults, lights on and the abs is off. Got vagcom which works on the later b4 tdi, but doesn't work on the early tdi or the coupe. I say works, it does most except it can't connect to the abs ecu.
I tried one of those snap on jobbies with the massive buttons for fat mechanics hands, which read the faulty codes on the coupe but again wouldn't connect to the abs ecu.
Is there a computer that'll work with these older ecus?
