seized rear calipers
  • benntenn67
    • Jun 2009
    • 859
    .... And another for the Irwin bolt grips http://www.machinemart.co.uk/shop/pr...=SRC-bolt+outs Get the add on kit too for a full set
    Audi S2 Coupe 1995
    VW Passat GL5 (hatch) 1986
    VW Passat GL 1.8 (saloon) 1986
    Carrera Subway 8
    • andy10v
      • 5996
      If you want to get it out just now I would try battering an old socket over the top, good use for those old af/whitworth/imperial sockets. It needs to be a proper hammer on fit, not just a few taps.
      Torx or multi spline bits hammered into the allen key may work, just stripped out for me in this application.
      Also if you get one out you can hammer/leverthe carrier back and forth to get the bolt and carrier rotating, so the bolt head is at least free from the hub carrier.
      Other suggestions would be good mole grips, penetrating fluid, heat or weld a nut on depending on what you have to hand.
      Sold ABY-stock
