seized rear calipers
  • 1781cc
    • Nov 2011
    • 1253
    Fronts were a piece of p*ss - rears however, are not so simple... so need a bit of advice on how to proceed...
    Bought new discs and pads to go on the rear of the diesel dog estate, and it appears that the rear caliper on the drivers side has seized into place, which is a right pain, but even more of a pain is that the caliper hanger is held in place with round bolts that are supposedly moved with an allen key, well, they would, but the slots have rounded and there doesnt appear to be any easy way to get the hangers off, which means I can't replace the discs.
    ideas anyone?
  • Christophski
    • 3632
    In the rounded bit hammer a slightly larger torx bit in as this will enable you to get it to turn.
    • spink
      • 4382
      yes either that or knock a socket over the top of the bolt,wtf were audi thinking when they used those ****** hex bolts on there I don't know
      • 1781cc
        • Nov 2011
        • 1253
        any ideas what size as I will need to go to halfrauds and buy one - sounds like a good idea though, thanks
        • irishs2
          • Apr 2009
          • 2455
          Mine were rusted and rounded on the rear too, and I hardly ever have any luck with oversize torx, but I have a vice grips with the jaws ground down that gets me out of trouble in that situation.
          Eric
          95 S2 Avant under rebuild.
          • SE_30
            • Apr 2010
            • 1114
            • Home: England Current: Israel
            Original Allen bolt is 8 or 10mm can't remember exactly now. If your going to hammer a torx bit in you want to be in the range of T40/45/50. And at a guess about a 13/14/15mm socket to hammer over the top of the Allen bolt..
            Make sure you've got your gloves on, reduces the hammer rash..
            Stuart
            B2 90 quattro with boost
            • 1781cc
              • Nov 2011
              • 1253
              thanks for the info on the Torx sizes, I dont for the life of me know why they didnt just put normal bolts on it, would have made much more sense in my eyes.
              I also have a pair of vice grips so will likely give those a try as well. Just need to get a set of calipers now - might pre-emptively get a left one as well to be safe.
              cheers guys
              • quattrostyle
                • Oct 2006
                • 6229
                I got a pair of rear calipers off a '95 Avant 2.0 if that's any help? Also with as good as new discs and pads btw
                • baltiboyS2
                  • 965
                  Heat them up first
                  cheers Raj
                  • PeterS
                    • 425
                    I do not know if they are available in the EU, but a set of IRWIN bolt outs has save me more than once http://www.irwin.com/tools/browse/sc...extractors...a set is less than $30 USD. i have used them on the CV and driveshaft bolts with great success, not to mention the rounded off head on the oil pan drain bolts...
                    Peter S
                    1990 ErsatzS2 - track toy
                    1991 Coupe Quattro
                    1991 Coupe Quattro
                    1995 S6 Sedan
                    1995 S6 Wagon
                    • sidrick
                      • Jan 2011
                      • 1342
                      I was going to suggest these. My set have saved me hours that would otherwise have been spent hammering/heating/swearing/bleeding.
                      I have a set I'd be happy to send, but I assume this is more urgent than the Christmas postal service would allow?
                      • andy10v
                        • 5996
                        x3
                        I have this set, worth its weight in gold, last used it for your exact problem on my 80tdi.
                        Sold ABY-stock
                        • 1781cc
                          • Nov 2011
                          • 1253
                          wow, never heard of those before - what a great idea - shame I didnt know about them before or I could have asked Santa :-)
                          Thanks for the offer Sidrick, really appreciate that but I think I am going to need to tackle it a little earlier than the new year!
                            Another vote for the Irwins. Not cheap but they are worth it.
                            • shaun5
                              • 1610
                              Another thumbs up for these
                              Reguards the use of Cap head bolts, if ordinary bolts were used it would still be a pain to remove them years down the line (they would round off) The area they are located means they corrode quite quickly, what they should have done is fit a small rubber cap over the head of the bolt.
