Calipers for 330mm disks?
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    God dammit there's soo much choice!!!!
    Someone make a thread with the definitive selection of brake calipers and discs with part numbers and bracket details
    • bilko0795
      • Feb 2011
      • 1883
      I use the Gt3 429/430 on my 345 x 32mm can't fault them
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        Where did you buy those rotors?
        • bilko0795
          • Feb 2011
          • 1883
          From Gsf, Merc ml 55 345 x 32 with the centre bored out from 57mm to 58mm
          • Rusty
            • 18953
            Boo hoo If only I didn't like having the OE 16" Avus on the car
            • robo
              • Aug 2004
              • 2086
              #21
              What bracket did you use?
              sigpic_________
              Rob
              • bilko0795
                • Feb 2011
                • 1883
                Only the best ( Bambridge )
                • Colesy
                  • Feb 2009
                  • 2983
                  Do they fit under 17's? I'd guess not...
                  • Vauhtiveikko
                    • Jun 2010
                    • 250
                    Same question here, can 996.351.429 Brembos fit under 17" RS4 replicas with 328 or so discs?
                    S2 Avant SleeperWagon 570hv and 765nm on 2,2bar/E85
                    • Thuppu
                      • 4115
                      Don't know about fitting on S2, but 17z calipers uses 330mm discs. Newer Touaregs also uses a 4-pot Brembo caliper that has replaced the 17z, I could be worth a look..?
                      http://www.audizine.com/forum/showth...-(low-cost-BBK)
                      • Vauhtiveikko
                        • Jun 2010
                        • 250
                        Hmm... by 17z means that can be fitted under 17". Any thoughts about those toureg heritage stuff price range compared to Porsche branded Brembos?
                        Can you Thomas make me the brackets for calibers?
                        • Thuppu
                          • 4115
                          The 4-pots seems to go really cheap sometimes. Look on ebay.co.uk and ebay.de. The finnish "varaosahaku" is also worth a look. There I found my 18z calipers cheaper than from ebay.
                          I can make adapters if I get a good drawing. Can't make billet machining, but cutting out of plate is no problem.
                          • PRY4SNO
                            • 767
                            But 32 wide too?
                            996s use 28mm wide as stock
                            Anyone have an answer for this?
                            2013 Touareg TDI /// #farmenwagen
                            • Audi_CQ
                              • 940
                              • Country: Norway
                              #29
                              17z for Touareg is available cheap as recondition units, but if you are thinking of using them for serious track use you have to keep in mind that the alu pistons transfer heat easily and can boil the brake fluid. BTDT...... There are stainless pistons available on ebay.
                              They fit under most 17", but custom brackets are needed.
                              • mac2226
                                • Jun 2008
                                • 1289
                                Yes I have some 17zr/zl calipers on my s2 coupe made to fit the discs I use 330mmx32mm
