Calipers for 330mm disks?
  • PRY4SNO
    • 767
    Originally posted by mac2226
    Yes I have some 17zr/zl calipers on my s2 coupe made to fit the discs I use 330mmx32mm
    What did you have to do the caliper to make the discs fit?
    2013 Touareg TDI /// #farmenwagen
    • mac2226
      • Jun 2008
      • 1289
      finding the right disc first then after that I got the hubs drilled and tapped so I use a counter sunk screw like new cars to hold disc in place as I hate how oem discs are not like this. Then had some brackets made up to suite the calipers to discs problem is the pad swept area on calipers pads I think there 65mm so there's not a lot of choice in discs and offset,and pcd they all need to be right otherwise it's a custom two piece discs which is more expensive but worth it as there lighter and transfer heat away faster
      • PRY4SNO
        • 767
        Interesting. I have some 330x32 Mercedes rotors kicking around that I'd like to use, might have to give it a go when my S8 rotors wear out.
        • Sirupracing
          • Aug 2009
          • 7
          • Country: Norway
          #34
          does anybody know where i can buy the 17z brackets?
          • IvillhaS2
            • Jul 2009
            • 16
            • Country: Norway
            #35
            I'm also after new brackets for the 17z with 330x32 discs. Verkline (AK Motorsport) made brackets for the 17z a while back, but now they only stock brackets for the 18z calipers. I tried to ask if they would make a set for me, and they just answeres that they wasn't available anymore.
            I have been running this setup for 4 years, but needed to replace the 17z with stock brakes due to MOT. One of the 17z caliper bolts snapped in the prosess and I had to cut the bracket i half to remove the brakes. Now I have one bracket left. Will try to get a machine shop to make some new brackets localy (if I can get a decent price).
            Maybe Verkline or someone else on this forum would be interested in making a batch if there is some more interest?
            • Sirupracing
              • Aug 2009
              • 7
              • Country: Norway
              #36
              where in Norway are you from? send me pm
