Warning light
  • scouser_75
    • 306
    Warning light
    Problems problems when I least need them!
    My brake warning light's staying on all the time (the red circle with the ! symbol).
    When I turn the car on from cold the light comes on for a few seconds, but then it goes out. It then comes back once I start driving.
    When I turn the car on from warm I get the "OK" symbol come up. And then straight after the OK symbol goes out the warning light is back.
    I've carried out the bomb test and that seems to be fine.
    I've recentely changed the rear calipers and was wondering if this would have something to do with it??? Or maybe I need some brake fluid???
    have you checked the sender in the top of the PAS reservoir isnt sticking?
    • S2 Ant
      • 3682
      Mine done what greg is suggesting.... i took off the cap and put it back in again and was fine, it got itself stuck when i topped it up.
      Hope its that simple for u
      Ant
      2011 Kawasaki Z1000
      • bob69
        • 118
        Had the same thing, check the connection to the cap as well - cleaned mine and prob sorted. Hope u get it fixed...
        '94 ABY
        • Fat Audi 80
          • 10547
          Yes, check the cap on PAS resevoir and Brake Fluid resevoir I think...
          The Perfectionist
          • s2driveruk
            • 12696
            could it be that the p/s pump is not capable of delivering enough pressure?
            1992 3b S2 Coupe
            • Doug_RS2
              • 3847
              I don't think so - I have driven my car without the belt on the power steering pump - no flashing lights, but hard work.
              • Graham
                • 1622
                When my crank pulley bolt came out my father towed me 7 miles down the road and my bomb powered my brakes all the way untill the road where the garage i was to be doing the repairs was. Once the pressure ran out it was skid marks time- stopping a 1.5 tonne car without any assistance is scary. And the steering was a bitch all the way
                • batty
                  • Jul 2004
                  • 81
                  Graham - I guess that wasn't skidmarks on the road then !!
                  • horvathg
                    • Dec 2003
                    • 556
                    I have the same warning light problem and since the cold came in it is on all the time. Bomb test suggest OK. Fluid levels checked.
                    Gabor
                    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
                    • scouser_75
                      • 306
                      Thanks lads Gonna check the levels and caps on the weekend.
                      I really do hope that this is all it is
                      Will let you know how it goes.
                      • horvathg
                        • Dec 2003
                        • 556
                        Shame on me. My servo reservoir level was OK I assumed, but just by topping it with two-three cm of fluid the beep and blink ceased.
                        Gabor
                          How many pumps is it ment to take to check the bomb? I did it while i was sat waiting the other day and got 57 pumps before the pedal went hard.
                          • S2 Ant
                            • 3682
                            i tested mine out last nite and hit 55.
                            Ant
                            2011 Kawasaki Z1000
                            • dog
                              • 100
                              I did the bomb test i got 58 but i have the flashing light when i start the car only for a while and then it switches off. I checked the needle and thats fine, n e ideas?
                              ON THE SEARCH FOR THE FOUR RINGS
