are there any guides on the net about how to change the bomb?
im not sure if mine is on the way out, but sometimes when you press the brake pedal down there is a vibration, feels like when abs kicks in but not as violent, and the pedal travels futher than it normally does.
sorry for hijacking post
Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
im not an expert in these matters as i cant even get my fuel acconomy above 12MPG,but my brother who used to work foe AM Quattros in Ilminster told me you can use a BMW bomb, same thing apparently and much cheaper. I await to be told im wrong, but hay!!!
Bomb is rather easy to replace...but to be sure you are ordering the CORRECT one, it may be best to get the part number off the existing one in the car. Also, it helps to have a strap wrench, essentially a rubber belt and a plastic arm, to hold the bomb securely while loosening or tightening the brake line connection.
