Rear brake replace/upgrade
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    Is it worthwhile upgrading the rear brakes for street use and big hp?
    I've been pulling the rear end apart and could with new discs at least, but might as well replace the lot since I'm rebuilding the whole car.
    Are there any alternatives that doesn't cost a fortune?
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
  • Nik0las
    • 1345
    • Country: Bulgaria
    S4 B6 rear brakes or S8 D2 rear brakes ..
    • Pat D
      • Dec 2011
      • 748
      Any idea on where's the best place to get them?
      B5 1.8T quattro
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        Take a look to see what you need ,but this setup requires hydraulic hand brake or separate small caliper for normal cable hand brake
        • Pat D
          • Dec 2011
          • 748
          Tempting, but I want to keep the cable hand brake set up
          B5 1.8T quattro
          • Simons
            • Jul 2007
            • 530
            • Country: Spain
            My rear brakes
            • SE_30
              • Apr 2010
              • 1114
              • Home: England Current: Israel
              Same conversion as AndyP' has done. All the info is available via S2central.net or if you scan through Andys thread you'll find a link for all the part number. Parts required are:
              B7 v8 300mm rear discs
              Urs4 callipers
              D2 S8 calliper carriers
              D2 S8 pads
              4 x 4mm spacers
              55mm x M8 carrier bolts shortened to correct length
              Stuart
              B2 90 quattro with boost
              • andy10v
                • 5996
                I went for this setup, works well. I needed new rr calipers/discs etc so figured it would be rude not to
                Originally posted by Pete Reeve
                These are the parts that people keep asking for-
                B7 Disc, 300x22 vented - 8E0 615 601R (2-off)
                A8/S8 carrier - 4D0 615 425C (2-off)
                Calipers from RR quattro or UrS4/S6 - 447 615 423 and 447 615 424
                S8 pads for those 280mm discs - 1J0 698 451L
                50mm long caliper carrier bolts - N101 815 02 (4-off)... Shortened to ~35mm for the task
                Also recommended along the way is new brake lines and clips for handbrake...
                S2 Coupe rear hose - 893 611 775 (2-off)
                Brake union clip clamps - 4D0 611 715B (2-off)
                Handbrake cable lock clip - N900 527 02 (2-off)
                This is what you get
                Turn the 300mm discs to 280, shorten 2 bolts, a couple of washers to center the carrier and it bolts on.
                There is a thread on here somewhere documenting it all.
                Sold ABY-stock
                • John B
                  • Apr 2008
                  • 926
                  Depends what you mean by a fortune
                  Anyway.....this set up is great http://www.s2forum.com/forum/showthread.php?t=62766
                  I might be biased though No seriously i am impressed with this setup. It is well-balanced and not too exotic.
                  JB
                  2001 996 C4 - Being renovated
                  1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
                  • afterburner
                    • Mar 2012
                    • 246
                    • Country: Bulgaria
                    Does anyone know if the caliper and support can take a 24mm thick disk?
