Poor Brakes.
    • Dec 2017
    • 6017
    I spoke to my VAG mechanic about this when I did my S2. The new G004 is a newer replacement but is still a mineral oil and basically the same as the old stuff. You must never use hydraulic or ATF fluid here but ONLY mineral oil.
      004 and 002 are compatible
      If it’s old I would change it a couple of times to flush the system through.
      Do it when you sort the bomb.
      • Jaydee
        • Jun 2012
        • 59
        Thanks for the input. Went for a short run yesterday and brakes seemed OK and pulled up evenly, however, for a short period there was harsh vibration at around 60 mph. Resting foot on pedal and you could feel the vibration. I have had this in the past and a quick dab on the pedal usually cures it. Thinking this is pointing towards possibly one of the pistons is out further than the second one therefore misaligning the pad on the disc ?? Of course it could be related to the 'bomb' if this is failing !!!
        On a complete tangent, went back to the car and noticed a leak on the floor - checked and petrol leaking from around one of the fuel line clips about 1/2 way down the length of the drivers door. Checked and it was definately petrol (car had been checked a couple of months previously as I thought I had a fuel leak, but had been discounted). See photo - Leak 2. Had another look this morning - see photo Leak 3, of whatever had built up around the leak area. Pipe is the one nearest the centre line of the car. If possible, will get it to garage to get it repaired next week !!!
          • Dec 2017
          • 6017
          Vibrations back through the pedal is normally warped discs, but should be there all the time if that's the case. It could be one piston sticking still as you say. Did you overhaul both sides with new seals?
          The fuel line corrosion is a common problem and well covered on the forum before. Replace the lot with cunifer. Don't be tempted to replace a small section that's leaking.
          • Jaydee
            • Jun 2012
            • 59
            Discs and pads are brand new - done maybe 25 miles. I was unable to replace the discs myself this time, but I did supply them. I suspect seals not replaced though.
            I have already bought the cunifer and compression fittings as I thought I had a leak previously. Just need to find my friendly mechanic with a lift - no fun on the drive.
            • Bowie69
              • Nov 2013
              • 2681
              Check your wheel nuts as well, and your driveshaft CV bolts to the gearbox flange.
                I expect they didn’t clean the hub face before fitting the new discs so you have runout.
                • Jaydee
                  • Jun 2012
                  • 59
                  Will do another complete strip-down and replace the seals as soon as I can. Will have a look at the driveshaft bolts as well, however, if these, or the wheel nuts were loose, surely I would get vibration all of the time - I am only getting vibration intermittently and there is no rhyme or reason to when, or why it happens.
