90q 20v rotor size?
  • Jolfa
    • Dec 2009
    • 468
    • Home: United Kingdom Current: New Zealand
    90q 20v rotor size?
    Pretty sure I already know the answer but can anyone confirm? Or any 80/90/S2 using G60 calipers?
    Typically they are the more expensive ones and the eBay seller I've bought them off has got it wrong!
  • mcandmar
    • Apr 2004
    • 5118
    CQ20v uses the same diameter disks/G60 calipers as the S2. Disk is something like 272mm i think. From memory not all 90 20v's had G60 calipers which might explain your issue. Certainly 10v cars had single piston calipers and smaller disks. Reason the 20v disks are so expensive is because they are unique in being the same dimensions as the S2 fitment, but four stud. So they only fit the CQ20v and 90Q20v, and possibly some V6 models.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • sam80quattro
      • Oct 2006
      • 1496
      276mm
        The European/UK Audi 90q with the 7A engine should use 893615301 front rotors that are 276 x 25 (vented) with 4 x 108 bolt spacings.
        • WidowmakerS2
          • Oct 2007
          • 354
          • Current: Norway
          276 mm ventilated up front front
          245 mm in the back.
          If at first you don't succeed, destroy all evidence that you tried.
          -CQ 3b "S2".
          • WidowmakerS2
            • Oct 2007
            • 354
            • Current: Norway
            Damn, too slow
            -CQ 3b "S2".
            • sam80quattro
              • Oct 2006
              • 1496
              Originally posted by WidowmakerS2
              Damn, too slow
              it was a close 1
              • Jolfa
                • Dec 2009
                • 468
                That's what I thought, cheers gents
                • Mikes2
                  • 1704
                  Unique to the 90q 20v in Europe/ROW. USA cars got 256mm discs
                  Coupe discs don't fit due to different offset hubs
                  Mike
                  http://www.s2-audi.co.uk
