CQ20v uses the same diameter disks/G60 calipers as the S2. Disk is something like 272mm i think. From memory not all 90 20v's had G60 calipers which might explain your issue. Certainly 10v cars had single piston calipers and smaller disks. Reason the 20v disks are so expensive is because they are unique in being the same dimensions as the S2 fitment, but four stud. So they only fit the CQ20v and 90Q20v, and possibly some V6 models.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
